November 24, 2024, 08:33:15 am *
Author Topic: Not Enough Memory 0.9z-7  (Read 13362 times)
« on: August 19, 2012, 04:36:56 pm »
I use Playback Drive now with a 8gb USB stick. It works allright but i get this message. Music keeps on playing though.
What is the message telling? Memory of DDR3 or is it telling something about the USB stick.
« Reply #1 on: August 19, 2012, 05:30:43 pm »
Normal memory. But you bring it as it were related to the USB stick ??
I think this is repeatable, right ? if so, try another album; I think it is the coverart. Not that it really takes too much memory, but certain type of jpegs make things go in a loop which in the situation I'm referring to ends up in too few memory indeed (no matter how many TB of internal memory there would be).
Can that be it ?
« Reply #2 on: August 19, 2012, 07:56:17 pm »
Well i do not have this when i play with folder XX on SSD and play from there.
And other cd's give the same error.
« Reply #3 on: August 19, 2012, 08:25:56 pm »
folder XX on SSD
Huh ? What do you mean by this ? That you installed XX on the Playback Drive ? If so, that sure won't work ...
« Reply #4 on: August 19, 2012, 09:22:44 pm »
folder XX on SSD
No no i have a SSD inside the pc specially for XX  Happy
« Reply #5 on: August 19, 2012, 09:30:23 pm »
Ok, I understand that it is a bit hottish, but did you mean to say anything with relevance in the bold text ?
And must I understand that the "from there" means the USB stick ?
« Reply #6 on: August 19, 2012, 09:36:04 pm »
forget the above i will try again.  Happy
1: Playing normal (as always) from ssd i do not get the error. (folder xx on ssd)
2: playing from USB does give the error. (Still folder xx on ssd.)
Hot indeed  Wink
« Reply #7 on: August 19, 2012, 09:43:51 pm »
Ok, thanks.
Well, it tells me nothing. Can you recognize that this occurs at each new track ?
Same with Unattended ?
What about another stick ?
« Reply #8 on: August 19, 2012, 09:47:00 pm »
Ok, thanks.
I will have to try when i get back from holiday. Two weeks.  Happy  Happy
But it happened after 4 tracks and than every new track give the message.
Thanx  Happy
« Reply #9 on: August 19, 2012, 09:50:38 pm »
WHAT ? Holidays ?
Ok ok ... Happy
« Reply #10 on: September 24, 2012, 02:22:39 pm »
I have no idear why i keep getting this message. I have it with almost every cd. It is really random and i cant see a pattern.
Music keeps playing so thats not it.
Can you remove the message?
« Reply #11 on: September 24, 2012, 04:15:20 pm »
Ok, thanks.
I don't think I saw explicit answers to this ?
« Reply #12 on: September 24, 2012, 05:07:02 pm »
Ok, thanks.
oh sorry.  unhappy
I have a playback drive now. 500 gb
Not with every new track. Sometime's a new track does not give the message. Most of the time's the first tracks of a cd does not give the message. It is so random that i can't see a pattern.
Unattended: That i will answer later. Il be back
« Reply #13 on: September 24, 2012, 06:47:04 pm »
Unattended does not give the error message.
