November 23, 2024, 02:44:54 am *
Author Topic: Coverart image aligns at the left side of the screen?  (Read 9360 times)
« on: August 17, 2012, 05:11:53 pm »
Any idea how to get that aligned in the middle of the screen?
« Reply #1 on: August 17, 2012, 07:21:08 pm »
Not. Or not yet. There will be a parameter for that.
This is for the remotes. See the Tutorials for that if you want.
« Reply #2 on: August 17, 2012, 07:25:26 pm »
Ah, okay. I wasn't aware that it is a known situation...  Rules
« Reply #3 on: August 17, 2012, 07:31:07 pm »
My bad. I really wanted to add that parameter,but here too, I had to stop somewhere for 0.9z7.
hwk
« Reply #4 on: August 21, 2012, 07:44:59 pm »
is it also correct that the coverart is not showing the whole picture, but only the top?
It's now a rectangle, not a square
gr, HW
Music Dedicated PC, Power: Silverstone Nightjar 300, MB: ASRock H87M Pro4 + I5 4570T + 4GB, Internal Memory: 16Gb Kingston DDR3-1333,  500Gb Crucial MX500 SSD with W10 Build 14393.0, 2x 4Tb WD 40EZRZ HDD for Music only), Soundcard: Seriously Modified Prodigy HD2 PCI Card 24 Bit/192 KHz with Amplimo's (van GooiPC), W10 10586-11 Home Edition 64bit
XXHe 2.11: KS mode: Special, Device Buffersize: 1024; Processor scheme: CORE 3-4; Player Prio: Below Normal, Threadprio: Above Normal, Clock Res.: 10 msec; HDCD on; SFS: 105.19,  Mem.Org.: Mixed Cont.; Q's=13x10,0,0,0; PE: Off, Custom: On; Playing Mode: Min.OS; XTweaks= On Indicates: "OPTIMAL": Bal.Load=45, Nervous Rate=99, rest=1  -  Sound Gear: Meridian 502 PreAmp (upgraded), 588 CD, 2x 505 MainAmp (upgraded) (all balanced driven), Speakers: Magnepan 3.5 SE, extra: Aphex 204 Aural Exciter; Cables: CD>Pre: Siltech SQ88, PC>Pre & Pre>Dedicated Headphones Class A Amplifier: John van Gent Reference+, Amplifiers>Speakers: Discovery 4; Headphones: AKG K1000 & Ultrasone Pro550 + dedicated Class A amp; Music Dedicated Power Group (copper shielded main cables + Oyade plugs) with parallel noise filter for the main-amps and PS Audio Quintet for the front-end. Analog: Micro Seiki DD33 modified, Denon301
« Reply #5 on: August 21, 2012, 08:52:01 pm »
No, I don't think so.
I suggest that you set the Height lower in Settings.
hwk
« Reply #6 on: August 21, 2012, 11:56:55 pm »
I see. So the cover isn't scalable anymore/yet?
gr, HW
« Reply #7 on: August 22, 2012, 08:55:02 am »
It is as scalable as it was ? It's only more oriented towards the top left corner at this moment.
Don't forget to judge including the OSD text !
