November 23, 2024, 06:30:56 am *
Author Topic: No sound at all in 09z-7  (Read 5985 times)
tillen
« on: August 16, 2012, 12:56:25 am »
After activating the latest version, I can not get any sound at all. Before activating, there everything was ok. The sound was better than ever :-)
Arnt
PC- Asrock X79 Extreme 4-M -
« Reply #1 on: August 16, 2012, 11:07:09 am »
Hi there Arnt,
No clue ...
I really can't think of any reason that this happens. However, certain sfs settings are prone not to play; this time it plays, the time it does not. Can it be something like that maybe ?
« Reply #2 on: August 16, 2012, 01:17:55 pm »
If you are in the full OS mode do you have the volume of Windows turned all the way down? If so that would be your problem.
tillen
« Reply #3 on: August 16, 2012, 02:04:10 pm »
Hei
Yes that was the problem. I found out 2 sec. ago but thanks anyway
Arnt  Happy
