November 23, 2024, 04:28:17 pm *
Author Topic: Music stops with Phase Alignment engaged  (Read 6311 times)
« on: August 15, 2012, 02:54:25 pm »
Probably related to http://www.phasure.com/index.php?topic=2156.0...
I'm getting a lot of stops when I engage PA. Interestingly, I'm using exactly the same XX parameters as I did with the last beta version of 0.9z-7 I tried, which didn't have stops with PA.
« Reply #1 on: August 15, 2012, 03:27:43 pm »
SOLVED! I just increased the SFS size from 280 -> 430
On my office PC (i7 860) with a NOS1, PA seems to work fine with the following settings:
- device buffer = 4096
- SFS = 430 (straight contiguous)
- Q1 = 30
- Q1x = 1
- PAx = 0
"Works fine" only relates to glitchless playback. The improvement in SQ is waaaaay more than "fine" (details being saved for another thread).
« Reply #2 on: August 15, 2012, 03:40:06 pm »
Hmmm... spoke too soon. Just got a stop, after about 45-60 minutes of music playing. I may try the Q1 factor at some point. But before this, I'll install 0.9z-7 onto Le Monster and see whether it fares better than the i7 860 I'm currently using.
praphan
« Reply #3 on: August 15, 2012, 03:56:58 pm »
Which version of z7 beta that you experimented with before the official release?  Mine is z709 which does not have the check box : "allow phase alignment". I guess Peter blocked PA feature in 709. When I first played around with it I thought I had it engaged until I noticed that I always had this _~_ on the cover art.
Dear all,
To avoid confusion, please add Q1 factor in your signature.
Thanks
Praphan
