November 23, 2024, 01:08:44 pm *
Pages: 1 2 [3]  All
Author Topic: 0.9z-7 - Minimize Button stays blue  (Read 34423 times)
« Reply #30 on: August 17, 2012, 03:35:14 pm »
Joachim …
What if we bet that Holland wins football from Germany and Holland wins if you are not going to understand Mani's last post. A strange bet maybe, but if I were you I'd now get the most serious. Because what if we win eh ?
Not that I care much, but hopefully you do.
Or otherwise … otherwise we declare you the most ignorant German in Finland. Does that help ?
I want to help - everybody does. But now how ...
the other way around you are not in the position to say where I can see this red framed picture. You see on Mani's print, that this red framed picture is outside of XXH. Eh?
Now I start my first beer!
* Mani.pdf (96.96 KB - downloaded 515 times.)
praphan
« Reply #31 on: August 17, 2012, 03:37:13 pm »
 yahoo yahoo
« Reply #32 on: August 17, 2012, 03:57:18 pm »
Some guys are very helpful and this is
a
very
good
recommendation for new customers!
I start now my second beer!
Eric
« Reply #33 on: August 17, 2012, 04:06:29 pm »
Christoffe,
your Picture "Proof of activation" is exactly the same as what I had yesterday.
However, believe it or not: my XXHE was NOT activated!
So I can tell you: it is very well possible that your XXHE is NOT activated. unsure
So, the solution starts with you accepting the possibility that your XXHE is actually NOT activated.
My solution was to Request a new activation code through PayPal and exactly follow the instructions as described in the manual.
Eric
« Reply #34 on: August 17, 2012, 04:12:18 pm »
As long as it is clear now that this 100% proves that this means NOT activated.
« Reply #35 on: August 17, 2012, 05:38:38 pm »
you see from this discussion/topic with the "Red Frame" that the manual ( http://www.phasure.com/index.php?topic=2131.0 //"Quote:There is no other indication than what's just described to see whether you are out of Demo Mode. Unquote//) is not precise/detailed.
This red frame seems to be the most important proof of a successful activation.
It would be very helpful too, that the access to the Wallpaper on the desktop is clearly documented. I did not anticipate that the "red frames" are behind the minimized XXH desktop view.
« Reply #36 on: August 17, 2012, 07:18:21 pm »
Joachim,
You should have because you were told a dozen times. Including pictures in the end.
I know what is described there and it is your good right to complain about it. Thanks for the tip and advice, but it stays like that. Maybe you refused to read the activation email as well ? Then so be it.
Best regards !
« Reply #37 on: August 20, 2012, 11:18:27 pm »
Since the topic of this thread has vanished a little in all the effort explaining what a wallpaper is and where to look for a red border (for the uncolourblind under us), I would like to bring it up again.
I most likely have an activated 0709 version, (with red border on the wallpaper coverart) and am quite shure I am in minimised mode (ie crossed loudspeaker icon after the reboot from full OS) but the minOS button is still blue.
Not only that, I cannot change its colour with a right mouseclick like in previous versions. Consequently, it won't let me go back into full os  unhappy.
Is this intentional or addressed in another version?
Btw I still have XXHE occasionally stop after 30 minutes or so.
regards, Coen
« Reply #38 on: August 21, 2012, 08:01:44 am »
Hi Coen,
I can't tell anymore whether 709 did still have Activation issues, but you bet it will one way or the other because we ended at 717 and it was all about that (so this is about yor stops).
That you can't even change the color of the button by means of the rightclick etc. is completely new to me.
What you should do it load (official) 0.9z-7 and as a first thing try to make the button red and boot into Normal OS Mode. If that worked all will be normal again. BUT, the very first needed is Activation because that is needed to change the OS mode.
You can also do it with 0.9z6 if you still have that around (Activated).
PS: I now recall that something like you talk about with the Minimized button has been in there. But I thought it would have been one of the last beta versions. So maybe not ...
Pages: 1 2 [3]  All
