November 23, 2024, 02:31:47 am *
Author Topic: Ripping using XXHE? - glitch removal  (Read 6984 times)
Martijn V
« on: August 13, 2012, 04:01:20 pm »
I have read very good reviews on your software, intent to start using it. Two short questions before download:
In several postst you refer to an application you wrote to detect or remove glitches.
- Does XXHighend also support ripping / file improvement, or is this an auto proces during playback.
- remote; read o lot about it, will the netwerk connectors still work during playback (use network connection to remote controll).
Thanks for your answers / forwarding to the right posts  Wink
Martijn
« Reply #1 on: August 13, 2012, 05:12:28 pm »
Hoi Martijn,
It should but it doesn't. It's in there (invisible) as a half-finished little project. Later, yes.
Notice that possibly I said the same 3 years ago ...
The question seems a bit inside out upside down;
As the tutorial(s) concerned try to describe, the whole thing is about having remote control *without* network. So here your answer is No.
This doesn't mean though that you *have* to do that without network. You can do it with, but now sound is deteriorated to a certain degree.
So in the end it is up to you ...
Hey, Welcome !
