April 19, 2025, 09:14:02 pm *
Author Topic: XXHighEnd Model 0.9m-1 (solves Engine #3 did not start ...)  (Read 7951 times)
« on: October 10, 2007, 06:13:43 pm »
As the title says ... at last stop of sound and the withgoing message "Engine #3 did not start within the expected time" has been solved (it took so long because I just could not find the cause).
What comes with it is a one "glitch" sample at Gapless which was found during the process of solving the above (in 50% of cases this happened).
Lastly, the text field for entering the Music Root (Settings tab) moved out of position at dragging the form size vertically. This has been solved.
No changes in SQ to be expected.
Edit : Wrong ... SQ just will be better for those who could not reach lower Q1 levels, but can now. Also see About 0.9m-1 ...
Important : If you are new here, do not forget to read XXHighEnd Model 0.9m (Implements Processor Core Appointment) before installing this version.
Current issue (must be since 0.9l) : The coverart in the right top corner sometimes won't appear, while at the same time the empty space won't be used by the track data. This (not always ?) can be solved by restarting the player. It seems related to the search function (Library tab) and loading albums or tracks from there.
Don't forget that clicking on the tabs should restore the coverart in the rioght top corner, but this now conflicts with clicking the Playlist Area tab just for showing it.
Will be solved in the next version.
* XXHighEnd-09m-1.zip (868.46 KB - downloaded 679 times.)
« Last Edit: October 14, 2007, 11:14:34 am by PeterSt » Logged
