November 23, 2024, 02:59:43 am *
Author Topic: Device Allocated But Cannot Play  (Read 13648 times)
« on: July 06, 2012, 11:06:50 pm »
Today I decided to tackle XXHE to get it to play again.
For some reason I did not use it much and was still using z6.
This gave me the device not allocated error.
Luckily I found this this thread and installed z6-1c and played around.
After going back from engine 4 to 3 I got music again.
I wonder if it is the HiFace-drivers or XXHE is making problems?
On the other hand it sounds very good now even with simple settings, attended, services on,
that I wonder if engine 3 is still inferior to 4?
And if so in what way?
Because a lot has happened and I think Kernel Streaming is Passé for MS...
What can I try to get engine 4 working again?
« Last Edit: July 08, 2012, 06:58:24 am by PeterSt » Logged
« Reply #1 on: July 07, 2012, 08:07:22 am »
Hi Gerard,
Obviously your post will relate to further posts in that topic, but I can't make up from your post what your problem is (merely : what happens). So maybe briefly "repeat" what happens at your place ?
« Last Edit: July 08, 2012, 06:59:25 am by PeterSt » Logged
« Reply #2 on: July 07, 2012, 10:49:44 pm »
Well, I get the 'Device Allocated but cannot play, check your dac settings, sample rate etc' error.
I checked and changed a lot of settings, but only going from engine 4 to engine 3 solved the problem.
I would like to get engine 4 working again.
But while using engine 3 I was wondering if this engine is really (still) worse than engine 4. As it is now I can not A-B between them. unhappy
« Reply #3 on: July 08, 2012, 07:13:29 am »
Gerard, can you post your X3PB log file from such a situation ?
Robert
« Reply #4 on: July 08, 2012, 09:55:17 pm »
Gerard I'm running the Young Hi-face driver now in Kernel Streaming with Hi-face M2tech with Engine 4. I had no problems with standard Hi-face drivers. Check my settings although I'm currently trying new settings as Peter suggested which I have updated on my postings.
Make sure you have the Hi-face KS driver/player highlighted in Device output of XXhighend when using engine 4. I find I have to reboot computer after changing major settings in XXhighend as well.
Perhaps go back to Hi-face manual its got all the relevant instructions for setting up for Kernel Streaming.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #5 on: July 08, 2012, 11:37:31 pm »
Thanks Peter and Robocop,
I'll hope to come back on this tomorrow, but not sure yet.
Almost holiday, a lot to do! wacko
« Reply #6 on: August 06, 2012, 10:25:50 pm »
The X3PB-logfile is empty.
This one not but is it helpfull?
Problem still exists on z7, engine3 plays, engine4 does not.
* X3-20120806-212208.log (88.88 KB - downloaded 495 times.)
« Reply #7 on: August 06, 2012, 10:57:40 pm »
Just found this one:
* X3PB-20120806-222606.log (0.98 KB - downloaded 523 times.)
« Reply #8 on: August 07, 2012, 11:47:37 am »
Hi Gerard,
I don't know. Maybe it works if you set your "DAC Needs" at 24 ? The HiFace driver I have (early version like my HiFace is an earlier version) at least can do that. I suppose the more current device + driver too. Maybe it helps.
But whether it does ot not, something seems to be wrong with the driver you use. Can't you try an older one ?
And what about Robocop's suggestion ?
« Reply #9 on: August 07, 2012, 09:02:40 pm »
Finally got it to work in KS.
Control panel-> Sound->Play->Hiface->Properties
There was a fourth tab where it said 44kHz maximum, after changing this to 192kHz 32 bit it worked.
But now the tab has disappeared..... scratching
Who changed that setting? Not me!  no
« Reply #10 on: August 08, 2012, 08:40:08 am »
Sounds like fun Gerard.
But you should tell this to the manufacturer I think. I know they are working on things ...
