April 19, 2025, 06:10:36 am *
Author Topic: Problems with stopping playback  (Read 8273 times)
Jon Ver Halen
« on: October 07, 2007, 03:34:38 pm »
I am running Vista on a Lenovo laptop.  When I ask XX to stop playing a track, either by hitting pause or stop, the last second of that track repeats endlessly.  I cannot get it to stop until I turn off the computer.  Sometime shutting off XX and restarting it will cause it to stop, but not always.
Is this an artifact of the demo version, or does my system have some incompatibility with XX?
« Reply #1 on: October 07, 2007, 04:13:06 pm »
Hi Jon. Most probably you have a driver issue. Sound hangs with Engine#3
Please come back on me if you can't get it away.
PS: Welcome !
Jon Ver Halen
« Reply #2 on: October 07, 2007, 04:55:30 pm »
Hi Peter:
I was trying this on my laptop sound card to verify it works, then move to an external USB DAC for the Rocky Mountain Audio Show later this week.  But I need verification that this will work fine before going to the show.  Are there any issues you see, other than my being a beginner and needing to learn too much too fast?
« Reply #3 on: October 07, 2007, 05:59:34 pm »
Jon,
The only problem I could see is that you did not find your best setting yet, and all sounds lousy ...
May be not the best for a show (which is not about XXHighEnd but about speakers I guess ...  Happy)
You know, audio ... heat
« Reply #4 on: October 07, 2007, 06:09:20 pm »
Additionally ... Q1 settings generally vary per DAC. So from what you have currently you can learn nothing. Also, I have the hunch that an SPDIF connection allows better "to get more from the DAC". I can't be sure though. It would count for my TwinDAC+ though.
