November 23, 2024, 01:16:18 pm *
Pages: 1 [2] 3 4  All
Author Topic: Problem using XXHighEnd with Terratec Aueron 7.1 Space  (Read 47914 times)
« Reply #15 on: October 26, 2007, 09:46:35 am »
You chose 24 bit. Should be 16 ...
WeHa
« Reply #16 on: October 26, 2007, 12:19:41 pm »
unfortunately there is no 16bit option i could choose. all the options are in 24 bit mode. so is there anything i can do to make it 16bit capable?
thanks.
« Reply #17 on: October 26, 2007, 03:32:32 pm »
No idea really. But it would hardly be true that 16 bits is not "allowed" by your card.
What about things like unchecking "IP Voice" ?
Or any other means of which you can expect to actually "downgrade" the card ... ?
WeHa
« Reply #18 on: October 26, 2007, 03:56:18 pm »
i've done both checking and unchecking the "IP Voice" option, but still doesn't change anything.
i feel completely hopeless to make this work
thanks Peter.
« Reply #19 on: October 26, 2007, 06:31:56 pm »
Bad luck so far. The laptop now just plays (at 48K/16). So now I can't try to tweak it ...  unhappy
But before it did not (Engine#3 of course) so I'm not sure what changed ...
« Reply #20 on: October 26, 2007, 07:56:13 pm »
Ok, I am as far now that I have your behaviour again;
Could you try to login to your PC as Guest and try again ?
I did not look for the differences yet, but logged in as guest (hence no admin rights whatsoever) it works, and with those rights (but not uplevelled) it does not.
Also though, with guest I have less devices (only loudspeakers, which btw I try to use, like you; with admin rights I also have SPDIF).
At first glance ... strange.
WeHa
« Reply #21 on: October 27, 2007, 02:39:22 am »
i've tried to log in as guest, but still it doesn't change anything. there's only 24 bit option. and when i tried to run XXHighEnd, an error message appeared. it showed something about Microsoft Visual Basic.
« Reply #22 on: October 27, 2007, 07:46:19 pm »
I am very sorry, but it can't be done (and the Guest thing appeared to be a mistake; it ran Engine#1 (but told 3).
Again I tore down everything in the software - but now for this situation (in my case the samplerate (your case would be the bitrate)), and again I bumped into this one "kernel" call where things go wrong.
On the other hand, you *must* be able to play 16bits. Note that you'd be feeding something into the stream (some DSP thing ?) when it outputs in 24bits only (or inputs ??).
Also note that when you'd manage, you will still be dealing with the Exclusive Mode thing (unless the same culprit causes that too).
Although there will be a difference in playback from Engine#3 opposed to the others, when all is subject to resampling (which it would in shared mode !), all is lost already, and you'd be "as worse" with Engine#1/#2.
I give up ... sorry
andy74
« Reply #23 on: October 30, 2007, 10:03:37 am »
Try reflash it to Prodigy 7.1 and use its drivers instead.
I personally tried it for XP, and the drivers and control panel a lot better for Prodigy 7.1.
I have a Esi Juli@. First I tried it with analog out as you did with space.
Then I realized that it is not exclusive anв not bitperfect, because it reponds master volume.
Then I chose Spdif out in the vista audio panel as default device.
I got no sound first but I noticed that in ESI panel I see that the SPDIF volume does not respond to master volume in vista.
I then just clicked on monitor button in ESI panel so that I can monitor what's going on the SPDIF through analog outs.
And viola, I have an exclusive mode for ESI SPDIF default device and monitor it via analog outs.
Changing master volume in Vista does not affect the volume in analogs out. And of course SQ is much better now.
I took a look at the Space panel at my XP PC and did not find a way to monitor SPDIF through analogs.
So I think you should google for Prodigy to see if its drivers allow you this. And if yes just convert Space to Prodigy (I did it myself couple of times).
Good luck
Andrey
WeHa
« Reply #24 on: October 30, 2007, 03:26:16 pm »
Thanks for the reply Andrey.
How I reflash my Aureon Space to Audiotrak Prodigy? Is it just installing the prodigy driver? or maybe you can help me with step-by-step-how-to-do-it?
thanks.
andy74
« Reply #25 on: October 30, 2007, 03:42:43 pm »
I checked on the net for prodigy driver and on the screen shot did not find how to monitor digital out through analogs. So reflashing may not help. It is up to you.
Here links to prodigy drivers
Korean site : the first link
http://www.audiotrak.co.kr/kr/customer/Dprodigy71.php
Another link
http://www.esiforum.com/show.asp?db=at&t=at1&mode=0&msg=2359
I would first read about prodigy drivers for Vista before trying to reflash.
I've sent you a PM too.
« Reply #26 on: November 18, 2007, 09:16:23 pm »
then when pressed enter :
I installed the latest version of XX on a test machine (since my HTPC is not ready), where the soundcard is an old Terratec DMX6 fire (which has a much better SQ than any newer TT cards) and I had the exact same errors as the above poster.
I'm trying to put the latest (beta) drivers for vista and the control panel but they seems buggy. I would like to evaluate XX on this computer that I currently use for music listening while working in my studio.
« Reply #27 on: November 18, 2007, 09:33:49 pm »
I managed to have the 5.51 drivers working (i didnt install the control panel), but they are far from optimal. With rca (line out) output to my active monitors I dont have exclusive mode and it seems that by default it upsample to 48khz.
It is very difficult to hear differences from WMP or foobar this way.
WeHa
« Reply #28 on: November 19, 2007, 01:29:03 am »
right now i'm downloading the via envy24 ht driver from viaarena which is built originally by via. because someone told me that the driver allow the device to operate in 16 bit mode.
WeHa
« Reply #29 on: November 19, 2007, 08:45:44 am »
OMG this driver couldn't detect VIA Envy24HT based sound cards. From what i saw on the website, it only supports Envy24HT-S which means the soundcards must use VIA DAC (less quality) ones. i'm using 0.9s-1 with engine #1 even i'm impress with the SQ. but still waiting and hoping Peter could solve my problem for using engine #3 Happy
