November 23, 2024, 09:48:21 am *
Pages: 1 2 3 4 [5]  All
Author Topic: Review of Nicks Tweeks  (Read 70551 times)
« Reply #60 on: March 03, 2013, 05:00:21 pm »
I understand. I was merely trying to find a way to overcome the inconvenience of having to open the case to reconnect a player...
But as long as one is happy with the tool of preference, that is more important than the convenience (or lack of) of course. We rip a CD for a long time (I hope) Happy
« Reply #61 on: March 03, 2013, 06:24:07 pm »
Very nice find Nick. I unplugged three SATA cables from the MB and had a really nice bump in SQ. Though subtle, the sound became cleaner and more focused. Will be an inconvenience when I want to rip music but it's definitely worth the bit of trouble.
Brian hi,
Good news.
Sorry to send you back into you PC again but i just found that this is worth a go as well.
Try using a SATA 3 cable (the ones with clips on them that come with the mobo) then plug your HDD it into mobo "SATA 1". Look at the printing on the mobo by the SATA ports, SATA 1 is one of the grey ports, it is a 6gb port but it sould work fine with a SATA 2 or SATA 3 HDD. I think this tidies the sound just a little as well.
« Reply #62 on: March 03, 2013, 07:35:59 pm »
What about a externe dvd writer\player?? I use that for a long time now.
Or do you think the quality is less with that?
« Reply #63 on: March 03, 2013, 08:12:54 pm »
Hi Gerard Happy
My guess is that the quality depends on the brand and/or player, but could also depend on the connection used. I am not sure about this. But I don't think that the internal/external would be the reason why a player would be better or worse.
I have a Plextor external player and one internal. 4 years ago, I was ripping with 4 players all working at the same time. I found that very useful then, but I am not sure I would do things that way again today...
listening
« Reply #64 on: November 04, 2013, 10:13:14 pm »
I'd like to share some hopefully interesting tweaks:
I have switched on HPET timer in BIOS a long time ago. Yesterday I read in different forums that W7 or W8 have not switched on HPET timer support normally.
- Open command window
- Enter "bcdedit /set useplatformclock yes"
- Reboot
(Use "no" if you like to switch back)
Additionally W8 allows to switch to a common hardware tick. Microsoft wrotes "Forces the clock to be backed by a platform source, no synthetic timers are allowed".
- Enter "bcdedit /set useplatformtick yes"
- Reboot
I'm courious about your feedback  Happy
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #65 on: November 05, 2013, 08:23:49 am »
Georg and all,
This is obtained in XXHighEnd already and through consistency with other settings. Manipulating these outboard is a. useless and b. confusing.
Btw, if you had looked at these both settings before you attempted changing them, you would have seen that they were already "set".
I could also ask you : And, did the placebo work ? (because already active) - haha.
Best regards (and thanks of course),
