gimignano
« Reply #60 on: June 03, 2012, 06:55:35 pm » |
Please, 1 set for me too. Thanks!
andreitour
« Reply #61 on: June 04, 2012, 10:58:23 pm » |
So should we submit a payment via paypal peter?
I just got back in town from a business trip and haven't had time to review the whole thread for instructions yet
dedicated XXHighEnd PC: Amd Phenom II x6, 16GB 1600mhz DDR3, Windows 7 Ultimate 64-bit on SSD, M-AUDIO - Audiophile 192, Bryston 3B-ST, Focal Cobalt 815
« Reply #62 on: June 05, 2012, 08:51:48 am » |
Here are the "instructions" :
Send an email to phasure .com (sales at) where the title contains litterally this text :
Bluetooth dongle - 3 sets - Eric
Obviously the 3 (sets) is to be replaced with what you want, and the "Eric" here is your nick name from the forum.
In that email type your address details so, that we can copy paste it into something printable, while that will be sticked on the envelope. Don't forget your country. Telephone number not needed. Payment details will follow in a reply to that email (and for many Paypal will be the cheapest means for this low amount). Don't use this email title to ask other questions please; we want to keep it clean.
« Reply #63 on: June 08, 2012, 04:19:23 pm » |
All,
Some people wonder whether their email correctly arrived because I am not (yet) responding to it; No worries. I didn't yet indeed.
When I responded to all (with payment details) I will let it know here. Then you will automatically see whether something went wrong (and nothing won't go wrong in the end).
Regards, Peter
« Reply #64 on: June 13, 2012, 07:55:45 am » |
Okay, everybody who sent email u/i June 12 should have received an email an hour ago. If that latter didn't happen please let me know. Notice that there is no text in the email body, but there is an attachment. It will come across somewhat "cold" I'm afraid, so let me send the warm regards to you all from here.  Peter
Eric
« Reply #65 on: June 13, 2012, 01:23:47 pm » |
Peter, Thanks for the prompt delivery of the dongles. Awaiting further instructions.
Cheers Eric
3.2GHz CPU, 8GB RAM, XXHE 1.186a, W7x64 SP1 Ultimate on 2.5" 10Krpm SATAII spinning disk, 8GB RAM / KS:Phasure NOS1 Out 4.0 / #4 Engine / Adaptive / Buffer 4096 / ClockRes 1ms/ Stop All Services / Monitor Off / SFS = 0.4 / not Invert / No XTweaks / Playback Drive = External USB3 (USB powered) HDD / Unattended/ Minimize OS / Peak Ext / ArcPredict / PA- / Q1,-,3,4,5=14,-,0,0,0 Control Panel: Sample Rate: 352.800kHz/ USB Buffer Size: 8ms Amps: BD-Design bridged Gainclones
ed linssen
« Reply #66 on: June 13, 2012, 05:04:50 pm » |
Hi PETER, Received the dongles today. Can't try them out I am affraid since I have a little short if how-to's. But, I am expecting a lot! Thanks so far, Ed
Dedicated music-PC: Asus P8Z77-M, Intel i7-3770K- W7 SP1-64bits and XXHighEnd 0.9-Z8-2 both on WD caviar black spinning disk(sata), music on WD caviar-black(sata),WaveIO Usb/I2S-- DDD1794 N O S DAC, 2 decks.192/24(Diy). IanCanada's FiFo in front of the Dac. (Buff3 dac,) Stereo. Amp: DIY-transistor fully class A, about 20watts/channel. Speakers: rebuilt ESL Quad 63. 12345: 70000, Q1, Engine4,playerprio:LOW,threadprio:real time.Scheme3, Dac=24/192, at 16bits=24bits, pe,ss,st.serv,st.Eng.4,tt,arc pred 2x(4x). Adaptive Mode/straight cont. Buff 4096, Phase -, Clock 15ms, Balanced 43, Nerv. rate 100, Cool 1, Stable 0, Core 1, Optimal, SFS 1-160, Incl. garbage coll.,Start Playback during conversion, Stop all services.Minimised O.S.
« Reply #67 on: June 13, 2012, 05:46:28 pm » |
Received
Stanray
« Reply #68 on: June 13, 2012, 10:34:45 pm » |
Received and waiting for  (no hurry)
andreitour
« Reply #69 on: June 14, 2012, 04:23:53 am » |
received an email / sent a payment
mood
« Reply #70 on: June 14, 2012, 07:30:32 am » |
mood recieved and paid
Monster Power cable,Gigab P-55-usb3 cpu 860 mem 16G, modded Musical v-link (tentlabs)aquvox lps, de groef interlink,musical fidelity V90 dac met lps rock grotto, audioquest usb cable, silverstone isolated from chassis w7 settings 1.186,W7 Ult min os q1-6,-,1,1,1,Qf-1,(stop all services on)engine 4,adaptive,buffer 4096/Playerprio= low/Threadprio=realtime/time 15ms/core 3-5/Minimized os/sfs=0,40 SC/Xt tweaks 64,1,1,0,2/Pe=on.Monitor =off,Osd=off
« Reply #71 on: June 14, 2012, 07:44:40 am » |
Hi all, You won't be able to do a thing with them right now. It first needs 0.9z-7 (don't ask) and the by itself ready instructions. Also, whatever you attempt with them now without instructions, may need uninstalling things which are not in the instructions because you did/implied that yourself (plugging them in is sufficient for that  ). Not a real big deal, but it is better to have the guidance match your experience (was that English ?). Regards, Peter
stefanobilliani
« Reply #72 on: June 14, 2012, 08:21:27 pm » |
WoW ! How Fast !
May 27 -2013 , 0.9z-9
W8 pro 64bit, UEFI sata ahci mode . i7 (8 cores ) 2600k RAM : 16Gig XXHE on OS disk Music on OS disk Playback drive on USB3 to 4Gig Pendrive Mobo USB 3 to Oversampling dac at 2X KS adaptive , ArcPredict , dev buffer 1024 Q1=8 , Q5=3 , res 1msec Minimized OS , stop all services X-tweaks : 45,100,1,1,1, stable , optimal Disk Utilization : Split File Size: 120 ,max the same as SFS Memory Organization : Straight Contiguous
« Reply #73 on: June 15, 2012, 09:58:58 am » |
WoW ! How Fast !  I hope my homing platypus makes it back in time for 0.9-7's release. He packed some extra vegemite sandwiches in his pouch so he should have the stamina for the Indian Ocean crossing
« Reply #74 on: June 15, 2012, 10:04:45 am » |
He packed some extra vegemite sandwiches in his pouch Should've given him Marmite...  Mani.
