April 02, 2025, 09:20:00 am *
Author Topic: 01 | I get a Class not registered error during installation. Now what ?  (Read 7603 times)
« on: May 23, 2012, 03:06:14 pm »
See below for the error concerned (although it is a Dutch version of it).
When this happens, undoubtedly your User Account Control is active, while it shouldn't for XXHighEnd. It is the most annoying anyway, so let's shut it off.
This is the Windows7 (SP1) procedure !
Go to Control Panel and in the search box (top left) type UAC. Now a subject Change User Account Control settings should appear.
Choosing that will show you a slider, and this slider should be dragged right to the bottom. After doing this, reboot ! This is important because necessary, and nothing will tell you to do so.
After the reboot, create a completely new folder for your XX install. This is important too. Once all is unzipped in there, run XXHighEnd.exe again, and now all will be fine.
« Last Edit: May 31, 2015, 04:49:30 pm by PeterSt » Logged
Page created in 0.025 seconds with 20 queries.
