March 31, 2025, 11:39:35 pm *
Author Topic: 00b | AutoHotKeys (Remote Commands) Listing  (Read 8588 times)
« on: May 23, 2012, 12:01:33 pm »
Here's a listing of hotkeys (shortcut commands). See below for version it is applicable to.
Alt-X   Start XXHighEnd
Alt-O   Quit Sound Engine (XXEngine3.exe)
Alt-P   Play
Alt-S   Stop
Alt-E   Pause
Alt-N   Next Track
Alt-L   Next Album
Alt-V   Previous Track ( N/A for UN-attended )
Alt-A   Set A point for A-B loop ( N/A for UN-attended )
Alt-B   Set B point for A-B loop ( N/A for UN-attended )
Alt-U   Volume Up
Alt-D   Volume Down
Alt-T   Toggle UN-attended/attended ( N/A for UN-attended )
Alt-K   Toggle "End after Track" (when used during playback, current track will finish and playback stops)
Alt-I   Invert (needs Alt-E + Alt-P to apply when used at UN-attended (or during playback)
Alt-F   Load Library Item ( UN-attended only )
Alt-C   Copy Track to "Nice Stuff" gallery entry (deprecated)
Alt-H   Copy Album to "Nice Stuff" gallery entry
Ctl-Alt-H   Copy Album to Gallery of choice ( UN-attended only via Remote and XXOSK (On Screen Keyboard ))
Alt-Z   Copy Track to "Demo" gallery entry
Ctl-Alt-Z   Copy Track to Gallery of choice ( UN-attended only via Remote and XXOSK (On Screen Keyboard ))
Alt-W   Copy Track to "Show" gallery entry
Ctl-Alt-R   Remove Active Track or Album from initiating Gallery ( UN-attended only via Remote and XXOSK (On Screen Keyboard ))
Alt-1 to 9   Used immediately before Alt-U or D to change preset amount per implied steps; 0 resets abusively used 1-9
Alt-M   Shuts off the Monitor (regardless of XXHighEnd settings) ( UN-attended only )
Alt-R   Brings back the Desktop and stops Playback when in UN-attended or starts Explorer when in Attended
Ctl-Alt-C   Clear Playlist. Needed when tracks are opened via Explorer and playback is to start at just opened track
Ctl-Alt-X   Stops Playback and Starts XXHighEnd ( UN-attended only )
Ctl-Alt-Y   Starts XXHighEnd and goes directly to the Library Area ( UN-attended only )
Ctl-Alt-N   Restarts Playback from a changed Playlist since Playback started last time ( UN-attended only )
Ctl-Alt-L   Starts the Services stopped by Unattended Playback in Minimized OS Mode ( UN-attended only )
( Updated for changes introduced in XXHighEnd version 2.06 )
For some ideas and further background, here is the old topic about this : AutoHotKeys listing.
Warning : When using the On Screen Keyboard (OSK), the Remote Commands implied by using the OSK can not be overruled by means of AutoHotkey self-configuration. However, Remote Commands can be added and they will be respected when using the OSK.
« Last Edit: May 30, 2016, 04:54:13 pm by PeterSt » Logged
