November 23, 2024, 09:32:12 pm *
Author Topic: Gettin message "Out of memory - Total picture size . . . "  (Read 13167 times)
Stanray
« on: May 22, 2012, 10:47:48 pm »
Possible this question has been asked before, but I wasn't able to find the answer.
With some albums I'm getting the message "Out of memory". "Total picture size in Cover art Pane too large? (can be 1000's of pictures)".
"Length of cover art file is zero?"
This happens with some albums, but I can't see why (the file-size isn't  larger than albums that don't show this message.
Anyone please?
Thanks.
regards,
Stanley
« Reply #1 on: May 23, 2012, 06:54:07 am »
Stanley, this is because of some incompatibility with JPEG somewhere, somehow. It is related to the faster means of how I determine the size of a JPEG and it doesn't work always.
Btw, I am pretty sure I worked on this throughout the process of creating 0.9z-7, so consider it solved for that version.
Stanray
« Reply #2 on: January 18, 2015, 11:13:09 pm »
I still get the above mentioned message with some albums.
Stanley
« Reply #3 on: January 19, 2015, 08:33:12 am »
Hi Stanley,
If you switch on Logging, then in the XX log file you will be able to see which image is causing the problems. You then may also be able to see what's special with that one.
You can attach the log file if you want.
I really never receive this message anymore.
Stanray
« Reply #4 on: January 19, 2015, 10:31:17 pm »
I attached a log file, hopefully you can make something of it.
Stanley
* XX-20150119-212045.log (1.03 KB - downloaded 544 times.)
« Reply #5 on: January 20, 2015, 08:11:08 am »
Hmm ... I'm afraid not Stanley. But you neither. But you can't tell which of those images does it ? If not, maybe we can think of you sending me those you showed (assumed it really must be one of those) so I can try to copy the behaviour  over here.
Stanray
« Reply #6 on: January 20, 2015, 09:22:40 am »
Yes, I think I know which images cause the messages. I will send some of them to you tonight.
Stanley
Stanray
« Reply #7 on: January 21, 2015, 11:19:27 am »
I removed the *.JPG files from the folders that caused problems, but the error messages remain.
However, the problem occurred with 8 of my 1702 albums and these were stolen torrents. In the end I just deleted them and I will try to get legitimate files  innocent.
So the problem is solved for my part.
Stanley
« Reply #8 on: January 21, 2015, 11:36:36 am »
Ah, OK, good.
But Stanley, do you still have one of those ? I mean, I rather solve the problem for a next one/time.
Page created in 0.108 seconds with 19 queries.
