November 23, 2024, 06:40:48 pm *
Author Topic: 32/352 very slow sound  (Read 31710 times)
« Reply #15 on: May 12, 2012, 08:37:34 am »
Thank you very much Praphan, and I didn't want to say it but that is sure what I recall (and should have tested anyway of course).
But now what ? I really can't imagine what could work out on any such driver differently while sure knowing that some kind of trick must be applied to get 384 (352.8 ) to let a DAC work at that rate while normally it can do 192 only. Or it just must be a commercial trick to sell another DAC (the Young) while it's really the driver coming with that which allows it (the 384).
Anyway, now what. Well, maybe that you don't use the latest XXHE version.
But Ivo, something must be wrong somewhere. Look here : Play settings for M2Tech Young DAC. That is you in there too you know. I guess you must elaborate somewhat ...
« Reply #16 on: May 12, 2012, 09:52:32 am »
No problem at all. Normal stereo sound at 352.8K
Praphan, just to be sure (because it is so ununderstandable for me) : This is 16/44.1 A.P. upsampled to 352.8, right ?
praphan
« Reply #17 on: May 12, 2012, 10:26:43 am »
Affirmative !
Red book 16/44.1 AP x 8 to 352.8 K. "Is NOS1" unchecked; SW5 off. Confirm no problem.
Thanks.
Praphan
« Reply #18 on: May 12, 2012, 11:16:18 am »
Thank you again Praphan.
ivo
Music lover
View Profile WWW
« Reply #19 on: May 12, 2012, 07:04:32 pm »
Yes, I am using latest XX. with 1c at the end.
Strange? Will read the thread you pointed and see if anything is not right.
Ivo
ivo
Music lover
View Profile WWW
« Reply #20 on: May 13, 2012, 01:15:54 pm »
In short:
It seems I have fooled myself a bit and you as well. But maybe not at least to some extent.
Details:
That file I got from 2L (24/352) and which I played via JPlay and XXHighend actually sounded equally wrong. The tricky thing is that it was symphonic music track unknown to me and it sounded ok, however, yesterday I noticed that while its original length is 3:03, actual playback lasted for approx. 5:30. Slow sound again. I cannot believe I did not notice this from the first time.
So, it seems that my system (PC) is capable of playing anything up to 24/192. If I go further, I get slow sound. Now, I think, I tried various settings last night and slow sound anyway. Even in MinOS mode unattended. What surprises me is that I have Core 2 Duo CPU (E6300) which actually is utilized just for few % while playing back 24/192. So I wonder why do I get slow sound if I double that.
At the end my theory is that my PC is probably too weak for material > than 192 kHz. Maybe you have other thoughts on this?
Ivo
ivo
Music lover
View Profile WWW
« Reply #21 on: May 13, 2012, 01:20:38 pm »
Did not mention what is "slow sound":
It is like when playback is slower. Imagine drums get hit slower and voice is stretched and rude. The tonality goes wrong, high frequencies are very attenuated. The easiest way to hear the slow thing is if there is voice. That is why symphonic stuff sounded kind of OK to me. Violins sounded as cellos and bass was catastrophic deep and muddy.
ivo
Music lover
View Profile WWW
« Reply #22 on: May 13, 2012, 01:47:33 pm »
When running 24/192 material without any upsampling, is it still a benefit to use "Arc Pred"?
Ivo
« Reply #23 on: May 13, 2012, 04:02:05 pm »
Well, nobody blames you for falling into that 2L "pitfall", or at least certainly not me. I experienced that myself with an earlier version of XXHE while I didn't know. In that case only the "not-upsampling" played too slow and I never noticed it with that 2L stuff. When I finally knew I presented it to two other persons for fun, and they didn't notice it either. The track lasted somewhat longer though (exactly twice  Happy).
Now your case;
I can't imagine that this happens because of a too slow system, especially if two players exhibit exactly the same while both ustilize not the same CPU amount. A driver issue ? then you shouldn't be alone. A hardware problem then ? not likely, but the best option if not a general driver problem;
When the "firmware" is not fast enough and/or bandwidth problems are implied, you get exactly what you have (an uneven speed (meaning : not exactly half or so)). Ask John, because he will know what his "trick" is - and I have some ideas about it (which I won't exhibit).
Btw, the firmware will be related to the driver, so it could be either which influences the other in a wrong way, so to speak.
No, it won't do a thing. Arc Prediction is only engaded when real upsampling is in order (so 2x at least for 192).
Good luck, and let me know when you have new information.
ivo
Music lover
View Profile WWW
« Reply #24 on: May 15, 2012, 10:58:12 am »
While waiting on John's reply:
Yesterday I recalled that some time ago I have been changing USB polling setting in registry.Thought that might affect the thing. I re-installed USB drivers and so did with Young driver and still sound is slow.
Could there be problem with USB cable? I think less likely.
When you mean "firmware" are you talking about some John's addition to the whole HiFace env? I think there is no a thing like that. I guess he uses M2Tech's HW and does not add anything? OK, just thinking loud.
Ivo
« Reply #25 on: May 15, 2012, 02:06:05 pm »
No, John won't be doing anything with firmware I guess. But he could be doing something which increases the bandwidth while the hardware (or firmware !) used is too critical hence can't cope with that.
Notice Ivo :
I already sort of said it, but in my view nothing that is related to the software side of things at the PC side (nor the hardware there) can incur for slower passing of the samples, unless it is an even multiplier (and then it will be a sheer bug)). So, only at the "drawing end" (the interface, the DAC - where the clocks are) can do this in a "stepless" fashion. It could even be a(n unintended) "filter" after the clock output, which makes the clock pulses run slower in effect.
ivo
Music lover
View Profile WWW
« Reply #26 on: May 15, 2012, 02:47:42 pm »
I bought JKDAC32 from him in January 2012. Recently in his webpage he announced that "now" JKDAC32 runs at 32/384 using Young driver.
I am starting to think: maybe he has started to sell new revisions of the same DAC which have this little "bug" solved. Maybe my early revision is just not running > 192 by design.
He is not answering yet, but if that is so, I will be very upset.
Thanks for support,
Ivo
« Reply #27 on: May 15, 2012, 06:23:43 pm »
What confuses me on his web pages (two days back at least) is that when you dive deeper, two JKDAC32's are there, one being able to do 192 and the other 384. This seemed redundant and wrong data to me, because somehow I associate the "32" to 384 at the same time. But this is not true of course. But anyway this is why I referred to that topic from January/February from this year and told you "you were in there too", making the same mistake : thinking you got the "384" in the first place. But apparently this is not true, as I see it now.
Anyway both versions carry the same price, and I would not be happy as a customer. But you can almost bet that John applied "some" hardware small change, related to the bandwidth perecived problem I talked about.
ivo
Music lover
View Profile WWW
« Reply #28 on: May 16, 2012, 12:08:57 am »
Thanks for looking @.
I think we can close the topic for now. Will inform if I hear anything back from John.
Ivo
Page created in 0.131 seconds with 19 queries.
