November 23, 2024, 04:14:09 pm *
Author Topic: 32/352 very slow sound  (Read 31704 times)
ivo
Music lover
View Profile WWW
« on: May 11, 2012, 09:29:08 am »
I am using https://sites.google.com/site/hifacemods/home-1/jkdac32 which built on the famous HiFace unit. Lately, it was discovered that it sounds better if used with Young's drivers (Young is 32/384 unit). Also, lately it was announced that John's remakes based on HiFace work well with Young's drivers and can be run at 32/384.
Problem: when I try to do so, the sound is somewhat 2x times slower. I run at KS Special 32/352 which is 8x upsampling from XX. Tried out many variants with buffers, Q1 and other. Nothing helps. Any ideas? Thanks.
Ivo
ivo
Music lover
View Profile WWW
« Reply #1 on: May 11, 2012, 09:31:05 am »
Wrong URL. This is right:
« Reply #2 on: May 11, 2012, 09:37:13 am »
Hi Ivo,
Did you also try Adaptive mode (IIRC the Device Buffer must be 2048 (and then Q1 at 1) ?
And what about WASAPI (Engine#3) ?
ivo
Music lover
View Profile WWW
« Reply #3 on: May 11, 2012, 09:38:41 am »
Yes, I tried Adaptive with 2048 and Q1 = 1. The same. When I tried Engine3, the whole thing crashed.
Ivo
« Reply #4 on: May 11, 2012, 09:40:40 am »
And the same problem with the normal HiFace drivers ?
ivo
Music lover
View Profile WWW
« Reply #5 on: May 11, 2012, 09:44:21 am »
Well, I have not tried 'normal' drivers because those are 24/192. As John mentioned, only with Young's we can try up to 32/384.
Everyday I play in 4x (32/176) and it is ok with both normal and Young's driver.
Have not tried Engine3 thou.
Ivo
« Reply #6 on: May 11, 2012, 09:49:39 am »
The normal HiFace also allows for 24 bits (DAC Needs). Does that make a difference ? (but be careful at trying)
ivo
Music lover
View Profile WWW
« Reply #7 on: May 11, 2012, 09:51:53 am »
I was using Hiface initially at DAC = 24/192.  All was fine. Now, for a while run at DAC = 32/192. All fine also. Sound the same.
Ivo
« Reply #8 on: May 11, 2012, 09:54:40 am »
(DAC Needs).
ivo
Music lover
View Profile WWW
« Reply #9 on: May 11, 2012, 09:57:09 am »
OK, got it. Yes, I guess tried also that, but not yesterday. Let me do some more tests tonight. @ work now.
EOF
ivo
Music lover
View Profile WWW
« Reply #10 on: May 11, 2012, 11:07:41 pm »
Tried just. DAC needs 24 and 32 bits. Both sound the same - slow. I checked, I have latest Young driver.
Could it be a problem with XX?
Hey, others! Has anyone tried feeding 32/352 or more into John Kenny's modified Hiface with Young driver from XX?
Ivo
ivo
Music lover
View Profile WWW
« Reply #11 on: May 11, 2012, 11:15:24 pm »
With WASAPI (Engine3) is exactly the same. While 32/176 sound OK, 32/352 is slow.
Do you need log files?
Ivo
ivo
Music lover
View Profile WWW
« Reply #12 on: May 12, 2012, 01:00:59 am »
I guess I found it...
Got 24/352 native DXD file from 2L. Played it back 'identically' on XX and on JPLay. Sound is OK, not slow. This proves that driver works OK.
I guess there is something in the way XX up-samples to 352 and 384 with ArcPred.
Ivo
« Reply #13 on: May 12, 2012, 06:54:55 am »
Odd.
Can anyone with an NOS1-USB confirm this by means of flipping Sw#5 up, deactive "Is NOS1" in XX Settings and next upsample 8x ?
I can't test this myself because in this mode my own NOS1 doesn't do the intended job for other reasons.
Thanks in advance !
PS: Ivo, you are using 0.9z-6-c1, right ?
praphan
« Reply #14 on: May 12, 2012, 08:20:50 am »
Peter Hi,
Just test using NOS1 USB with the setting you asked for.
No problem at all. Normal stereo sound at 352.8K
Turning on sw5 will kill right channel as usual.
Praphan
