November 23, 2024, 05:53:45 am *
Author Topic: Images won't load on installation page "Installation guide for Dummies"  (Read 11641 times)
charliemb
« on: April 30, 2012, 07:00:34 pm »
I load and reload many times and cannot get the images on your "Installation guide for Dummies" page to load.
I see no images of the screen captures.
Like this, the page makes little sense.
July 2019:
« Reply #1 on: April 30, 2012, 07:27:05 pm »
Hi Charlie,
Please try to locate something at your side. Firewall settings ... I reall don't know. I mean, it just works ... (I checked it).
Can you see the below image ?
And if not, this image in particular you don't see in the original post ?
« Reply #2 on: April 30, 2012, 09:55:38 pm »
They don't load here either. I can see the picture you are referring too in the post though, I guess your server is extremely slow and that this is causing the problem. Perhaps they will show after a very long time but waiting for 5 minutes and still nothing (no pictures, only a busy loading signal).
Downloading sofware from your server takes a very long time too (reminds me of my old 14k4 modem downloading forum messages taking ages...).
Could be something else though, I am not the expert.
PS, I looked at the source code of that topic and there the images are linked to a directory at www.stordiau.nl and going directly to that webpage shows the same problem (nothing shows).
« Reply #3 on: May 01, 2012, 04:02:25 pm »
Aha ...
The site in question couldn't be reached from outside. It did from inside (which latter is how I "checked") ...
It should work again now.
Thanks !
praphan
« Reply #4 on: May 01, 2012, 04:18:48 pm »
Aha ...
Thanks !
I just checked it now. All the screen shots are there and being loaded at light speed.
Praphan
charliemb
« Reply #5 on: May 01, 2012, 09:49:16 pm »
It works now!   Thanks.  (fooled by the old "inside access" trick)
They load a little slow but there is a lot to download and it is fast enough.
All is well.
July 2019:
« Reply #6 on: May 02, 2012, 02:56:16 am »
Here in California and all screenshots loading very fast.
« Reply #7 on: May 02, 2012, 09:00:20 am »
No problem in downloading the screen shots here too.
