November 23, 2024, 04:40:07 pm *
Author Topic: Sorting Order  (Read 18656 times)
CaOd
« Reply #15 on: April 08, 2012, 07:58:17 pm »
Ok, NTFS formatted, copied the same way like before and -tataaaa- works, i.e. shows up in the right alphabetical order.
Why FAT32? Because I have no real clue about computers and the external HDD was recognised by both Operating systems ok, and this one is FAT32.
As said previously, I am setting up a MacBook Pro with a dual boot system, so I can boot into a MAC OS or (just for XXHighend) into Win7 SP1. I have a second internal HDD instead of the optical drive to hold my music and this drive should be readable from both OS, so I had decided for FAT32. Seemed to be the wrong decision, should be NTFS?! I can do it all over again, shouldn´t bother or take too long to copy the 700GB... the night is still young.
Is that the solution, Peter? Or any disadvantages in my setup with a NTFS format?
Thanks Carsten
August 26, 2013 (0.9z-9b)
MacBookPro 15" i7 2,4Ghz,16GB,Win 8 Pro 64bits, OS on internal SSD, XXHE on internal SSD, Music (WAV) on spinning disc, loaded on Ramdrive,
Engine#4 Adaptive Mode / Q1/2/3/4/5 = 15/0/0/0/5 / Q1Factor = 10 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / PA off / SFS = 120 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 / UnAttended (Just Start) / All Services Off /XTweaks : Balanced Load = 45 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Minimize OS = On / 4 times Arc Prediction Upsampling  -> Weiss DAC202 (modified by Klang&Kunst) -> Jadis DA50Signature -> Audioplan Kontrast V
« Reply #16 on: April 08, 2012, 08:26:51 pm »
Started ut with Google :
fat32 sort directory
and read a few things. Maybe this does the job fine : http://foldersort.software.informer.com/
If that is not available anymore, here's a thread that looks to help out : http://www.toyota-4runner.org/5th-gen-t4rs/67765-usb-folder-sort-order.html
Be careful with it.
Of course this keeps on bugging you when new albums/folders are added ...
Disadvantages with NTFS ? I don't think so. Yea, compatibility. Your NTFS formatted USB stick won't work in your TV now anymore - for example ...
