April 08, 2025, 10:21:26 pm *
Author Topic: Windows 8 playback works!  (Read 25954 times)
« Reply #15 on: April 10, 2012, 10:41:15 pm »
Remote control - sounds like you have spent many hours Peter. A problem to really get your "teeth" into.
Well whatever the solution to remote control I hope that it matches the colour of my NOS1  very happy
All the best
gsbrva
« Reply #16 on: April 13, 2012, 03:00:48 pm »
Update:
I was able to confirm that the difficulties I had were the result of strange User Account Control issues and not the XX installation.
I tested if by running the same installation of XX from other user accounts in Win 8:
A user account with administrator privileges (default) doesn't seem to work.
A user account without administrator privileges can run XX if you run as administrator and type in the password.
The built-in administrator account works without hassles.
There is a small downside to using the built-in administrator account, since some of the "toys" in the new interface say they are not available with this account.  It's not a big deal if you just want to listen to music.
I also use this computer for home theater video playback.  Netflix and movies off the hard disk work fine with the Administrator account.
The UAC problem might be a bug in this version of Win 8.  If it gets fixed in an update, I'll post a note.
Digital playback system = XXhighend 0.9z-6-1c KS adaptive (engine 4), Dev Buffer 2048, straight contiguous > Windows 8 64 bit preview, Quad core Q6600 Intel 2.4 ghz, 6gig memory > P965/ICH8 chipset w/usb PCIe NEC USB3 card > Hiface Evo > I2S > NOS TDA1545A/1387 w/Crystek CCHD-957 clock chip backfeed to Evo ext clock in > dac current output into low Z transformer input Altec A256C beam power amplifiers> Quad ESL63 pro
stoni
« Reply #17 on: October 14, 2012, 12:48:51 am »
Yes it does, and it works great! Since I've free access to W-server software, I've tried out W2008/2008R2SP1/2012. The very best of them is the newW2012, the sound is fuller, less edgy, more analogue like, the difference is not subtle! XXhighend on W2012 runs like on W2008, but so far I've not tried the Min OS funtion, first I need new activation keys, I had to do a fresh install because off partition problems.
Now I've W7 for media purposes, loaded with functions, and a minimal W2012 for XXhighend (I know Peter doesn't like me to mess up with to many OS's prankster)
February 2019
W10-10074 (2.10c)
*XXHighEnd Mach III, ffrom RAM, music on LAN / Engine#4 Special Mode / Q1/-/3/4/5 = 30/-/0/2/1 / Q1Factor = 40 / Dev.Buffer = 256 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 171/ not Invert / Phase Alignment on / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / All Services Off / Keep LAN - Not Persist / WallPaper Off / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = *35* / Nervous Rate = 10/ Cool when Idle = na / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Stable / Time Stability = Off / Custom Filter off / Arc Prediction on Upsampling off/ -> USB3 *from MoBo* -> Curious USB 15cm -> Intona Isolator -> Curious USB 1m -> Ayre QB9 DSD DAC (modified) -> Jeff Rowland Continuum S2 ->B&W 803d2 (heavily modified)
« Reply #18 on: November 17, 2012, 02:41:35 pm »
Look here for the solution as of now : Windows 8 Tutorials - Change Registry for proper UAC rights
