November 23, 2024, 07:08:22 pm *
Author Topic: Feedreader  (Read 11893 times)
« on: September 26, 2007, 01:09:58 pm »
Is it possible to introduce RSS news feed?
Regards, Johan
« Reply #1 on: September 26, 2007, 02:59:59 pm »
Hi Johan,
It is just there. Maybe read this to get it going.
With Feedreader3 you can use it.
You can use IE7 instead (might even work better).
More questions ? I don't have the answers. blush1 All I know is it just works from another SMF forum I "own" (with above mentioned links/tools).
« Reply #2 on: September 28, 2007, 09:25:19 pm »
'...There...' was no succes (Spam, registration eg.) ! I presume You don't want to introduce the "feeds" (for each item) on this Forum!  unhappy
Johan
« Reply #3 on: September 28, 2007, 10:05:03 pm »
I'm not aware of that Johan ...
« Reply #4 on: October 02, 2007, 11:45:51 am »
Okay, I tried it myself. I really don't see the problem ...
Don't look at the "Today" and times as shown in the screencopy below. That will be settings of Feedreader I don't know (and don't want to find out). The main point is : it just works.
« Reply #5 on: October 02, 2007, 10:12:11 pm »
Normaly when you need a feed there is a special RSS button on a side so you can copy the feed in de feedreader. On your side it is enough to be on the side and the open the Feedreader and select the menu option FILE => NEW => FEED. In the feedreader you get automatic "http://www.phasure.com/index.php?action=.xml;type=rss;limit=20" And the the job is done. It works Great! Sorry for the trouble.
Johan
