November 23, 2024, 05:56:30 am *
Author Topic: Cracking noise with 48/24 flacs @ 16X NOS1usb  (Read 20021 times)
« on: March 07, 2012, 11:23:51 am »
I was in the mood for some classical music and have a truckload of 48/24 FLAC files from B&W SoS. I observed a very audible and annoying haze of "tics" when playing (all) of these tracks with my normal settings (below). When the level increases the cracking haze becomes more prominent.
Throttling back to 8X AP everything sounds normal again.
Did I oversee a setting or is this some kind of bug or limitation?
Regards, Coen
« Reply #1 on: March 07, 2012, 11:41:15 am »
Some more info: on thesetracks the clockres warning appeared. Some times with 1mssometimes with 10ms.
Nos buffersettings and other dials make no difference.
Regards, Coen
« Reply #2 on: March 07, 2012, 11:49:46 am »
No. It most probably is something which really is wrong. But allow me to ask you a few questions by email (about your wife's name and such swoon)
« Reply #3 on: March 07, 2012, 11:52:43 am »
If that would be caused / implied by the sample rate, it would be the most interesting (not meant cynical !).
« Reply #4 on: March 10, 2012, 12:01:22 am »
These messages appear to be related to Changing the AI setting (from 16x to 8X). After two stop-and-starts no more messages appear.
Regards, Coen
« Reply #5 on: March 10, 2012, 09:17:47 am »
Coen,
Can you be more specific ?
"AI" 16x and 8x does not exist, although you certainly can try to set it. So, what is which and when, and where do you attempt Play etc. - and exactly when does the message not appear anymore.
« Reply #6 on: March 10, 2012, 03:02:07 pm »
Oops late night mistake. I meant AP of course (as in my signature).
I set the slider from 16x to 8x in order to play the 24/48 files noiselessly.
Regards, Coen
« Reply #7 on: March 10, 2012, 05:53:57 pm »
Ehm, and now say it is too early ?
You were talking about messages, and I wanted to know when they stopped appearing.
Your cracking noise (by itself the subject of this topic of course) was another story.
I think.
« Reply #8 on: July 03, 2012, 07:32:21 am »
I have the same problem with 24/88 and higher Flac's. When I set the AP slider back from 16 to 8x this solves the problem. Is there another solution for this problem?
Johan
« Reply #9 on: July 03, 2012, 08:28:06 am »
Johan,
Report Peter of the NOS1 driver errors when playing with the 48x16 setting.
Regards, Coen
« Reply #10 on: July 03, 2012, 08:55:01 am »
48x16
Sorry I don't know what you mean by 48x16 setting.
Regards Johan
« Reply #11 on: July 03, 2012, 11:16:03 am »
Sorry, I was very unclear. I just meant the 16x AP setteng where the cracking occurs.
If you start the nos driverpanel you have to select the 'errors' branch and see what has happened (or happens) during the cracking noise.
Regards, Coen
« Reply #12 on: July 03, 2012, 12:54:03 pm »
Hey Johan,
Although your problem will, to Coen, look the same as his problem back then, I don't think you have the same problem. But to know this, you must tell quite exactly when this happens. So, what you actually say is that it only happens with Hires files (and mention 88 as a base). But is this so ? or is it about 48 based files only, and already so with 24/48  ?
I hope I have been clear enough ...
« Reply #13 on: July 03, 2012, 06:08:45 pm »
Did some tests.
24/48, 24/96 & 24/192 flac give all cracks in the sound. Usb audio console gives fifo errors. Reducing from 16x to 8x no cracks in the sound and no fifo errors.
Johan
« Reply #14 on: July 03, 2012, 06:20:02 pm »
Ok, clear. See your email in an hour or so ...
