Hi there Snowland,
Although Coen is completely correct, it may not tell you a thing as an "outsider". Maybe I can't explain it better, but I'll try :
Some programs "manipulate" the Clock Resolution of the system; this may be to have them respond better. Say it is the overall response of the system which is influenced by it. The lower the number (like 1ms is low) the faster it responds (once per 1ms).
It is not said at all that for audio it is better (SQ wise) to have the system respond fast; therefore it can be set within XXHighEnd. But, once another program (like the examples Coen gave) requires a lower setting, "we" can do what we want, it won't get higher if we want it. First that other program has to let loose of its requirements (has not to be there, generally).
WASAPI itself (in the system internals) does the same. It sets all for itself to 10ms. This is what the message tries to tell you *if* it were about those 10ms. But in your case it is 1ms.
Now watch out : WASAPI too can require 1ms, but this is related to many other things (say, out of our control). So, if you do not get the message from Kernel Streaming, it *is* WASAPI itself doing it to you. But in the end it is your OS, and your possible tweaks to it.
Note that WASAPI is Engine#3 and KS is #4.
When you want to use WASAPI and you receive "stuttering", try to get that out of the way with the Q1 dial. Start at 14, this usually works for everybody. Downwards usually gives the better sound.
Lastly, there is no way any system Volume Control will work; this is deliberate (because bad for SQ). The Volume Control from XXHighEnd is to be used without preamp. Try this "easily" because it is not a fast resonding thing, and when it gets behind things may choke.
It works best in Unattended Mode (no GUI is there then), then controlled by Alt-u/Alt-d (or Alt-5 (etc.) followed by Alt-u to imply five 1.5dB steps in one go).
The Volume Control in XXHighEnd is one of its kind, and it is "lossless" (out of the attenuated data the original can be recreated).
Hope this helps !
