November 22, 2024, 07:07:07 pm *
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14  All
Author Topic: PCIe USB 3.0 host card  (Read 237452 times)
0 Members and 13 Guests are viewing this topic.
« Reply #60 on: March 20, 2012, 08:06:08 am »
Juan, I wanted to mention it before, but I am not sure about it at all ...
For USB3 there's a "USB3 Monitor" (something like that name) process/service. With Minimized OS that won't be there, unless you exclude it from the shutdown list. Maybe, just maybe that is needed here ?
I use USB3 discs without it (I uninstalled it), so it won't be about that. But it should be about something ...
« Reply #61 on: March 20, 2012, 09:36:56 am »
Something like a USB 3.0 monitor? I never saw that before, I´ll try to find it. When I reinstalled the OS I tried to connect the NOS1 even before I installed the XXHighEnd and I couldn´t find the NOS1, nor after XXHighEnd was installed.
As the use of the USB 3.0 port is a clear improvement I wonder if wouldn´t be necessary an upgrade in the NOS1 to make it able to take the full advantage of USB 3.0.
« Reply #62 on: March 20, 2012, 10:28:58 am »
I wouldn't be too sure about that ... yet.
This is not at all what I perceive from the various posts.
Btw, I am waithing for my own "gear" to arrive, so I finally can try something myself heat ...
« Reply #63 on: March 20, 2012, 01:17:29 pm »
What also should be tested is a PCIe usb2 card. Or do you have such ordered.
Or would that not be?
« Reply #64 on: March 20, 2012, 02:23:15 pm »
Gerard hi,
I have tried PCIe USB2 cards in the past. Probably because no manufacture wants to invest in production of a native PCIe USB2 chipset all of the ones that I have looked at are just a standard PCI USB 2 chip (as you would find on a PCI USB 2 card) with a PCIe to PCI bridge chip placed in front of it. This steps the bus speed back down to PCI bandwidth and is another step in the chain. The sound when tested was broadly similar to a normal PCI USB 2 card, possible slightly worse. I am not sure this would be worth testing.
Best,
« Reply #65 on: March 20, 2012, 02:34:00 pm »
I have also been looking for patterns in the reports.
I was thinking that the maximum benefit (assuming hardware and bus speed contribute as well as software) would be for folks who fit a PCIe USB card to older motherboards with only USB 2 support but access to PCIe buses. This is the case for my PC.
Interesting to see that Praphan seems to have had minimal benefit using mobo USB3 ports (if I am correct) on a high spec PC but Paul also on mobo USB 3 (again if I am correct) and is getting heavenly results  Happy.
Cheers Nick.
« Reply #66 on: March 20, 2012, 03:32:07 pm »
Cheers Nick.
Maybe the people with older mobo can get a more important jump in sound quality, relatively speaking, using a PCIe USB card, but the ones with more modern mobos with native USB 3.0 ports, as myself, get a very notable improvement in sound quality, even as in my case are only able to use the USB 3.0 port with an USB 2.0 cable.
As I said in other post I can perceive a fuller sound, I mean the sound is filling up the room in a bigger way and it is done with a great sense of continuity and without empty spaces in the imaginary soundstage. Also the sound is very relaxed like someone else said (Paul I think) and it is more evident than ever that the standing waves have less presence, if any.
In few words, the sound is bigger, more relaxed and cleaner. And it is noticeable.
« Reply #67 on: March 20, 2012, 07:45:21 pm »
I have a usb3 mobo with etron pcie usb3 chip that does not work as expected. Another reason to get a PCIe card.
My impression is that USB3 is beneficial, but I am still in the process of getting my system working as it should, applying lots of changes to the setup (os). Up untill now I have not felt the need to remove it.
Regards, Coen
« Reply #68 on: March 21, 2012, 10:22:18 pm »
... Hooked up to one of the MoBo's USB3 ports. The other (only) one connects to the USB3 disc I'm playing from.
Measurement-wise, I saw no difference anywhere. For possible driver (latency) etc. settings ? no difference again anywhere. However ...
When serious playback and listening had started, I brought up XXHighEnd at some stage, crossed it away and heard a crackling sound (as loud as the music I'd say). *Never* heard that before.
A minute later, I touched the Alt button for Alt-X - same sound.
After this I couldn't copy this behaviour anymore, but possibly didn't wait long enough for ? ... I don't know.
Later again, I cleared the Playlist Area (Unattended still playing) and again that crackling sound (lasts 0.1 - 0.2 secs).
To me this does not look good.
Btw, the NOS1 did not need to install on this never before connected-to port. It just worked right away.
Sound-wise I am not conclusive yet.
« Reply #69 on: March 21, 2012, 10:39:52 pm »
I have had crackling using the card Nick has. But until now the good sound makes it worth.
As you say at the beginning but also at the end.
Peter in the beginning you say Hooked up to one of the MoBo's USB3 ports. You mean PCIe?
« Reply #70 on: March 21, 2012, 10:47:13 pm »
... Hooked up to one of the MoBo's USB3 ports...
Connected using  an USB 3.0 cable or the USB 2.0 one?.
« Reply #71 on: March 22, 2012, 07:31:43 am »
Of course you thought I had the time to sort that out.
IOW, no idea ... sorry
Anyway no extension card.
USB3 A-A (1.8m) & Genderchanger B-A.
« Reply #72 on: March 22, 2012, 10:03:45 am »
I also had the crackling. I don't think onboard or pci card usb3 matters, they are seperate chips anyway (only ivy bridge has native usb3), the chipsmanufacturers may differ though. When having the pcie card in the 16x gpu port there was significant cracking caused by the cpu. Error counters in the driver panel went bazerk. Still the cracking is visible in the usb and fifo error counters.
I also had cracking during play, but that seems to be fixed by increasing the minimum clock% of the cpu (in power management).
No definitive comment on sq yet.
Regards, Coen
« Reply #73 on: March 22, 2012, 10:51:17 am »
No FiFo errors or anything on this side - but I didn't check that when the crackling occurred. So, no problems anywhere during normal playback.
« Reply #74 on: March 22, 2012, 11:16:52 am »
For what it is worth I have not experienced any cracking at all. When I first connected via USB3 NOS1 was not recognised so I had to power down and then power up NOS1 to get USB3 recognised.
My USB3 is on the main board.
Still sounds good  Happy
P
Page created in 0.123 seconds with 19 queries.
