November 22, 2024, 07:10:49 pm *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]  All
Author Topic: PCIe USB 3.0 host card  (Read 237456 times)
0 Members and 14 Guests are viewing this topic.
« Reply #195 on: November 30, 2012, 10:34:53 am »
Stupid question : Did you connect the addtional power to the card ?
When you are in the stage of being able to bring up the NOS1 Driver Control Panel, does it say at the bottom that streaming is running ?
(when Yes, please check again whether playback still is not possible with that Paused Pin thing message and let me know the result)
What you can try is uninstall the NOS1 driver and reinstall it (take care that the USB3 card is in the PC at that moment).
Tore
« Reply #196 on: November 30, 2012, 01:19:06 pm »
The blue screen with text is ther only 1 second, but in the next line i can read : Driver equal not ....
The card is connected with powercord inside PC.
I have alredy tried to reinstal the NOS1 driver
Tore
« Reply #197 on: November 30, 2012, 02:03:21 pm »
That would be "driver equal not zero" I think but I'm not sure whether this "driver" isn't to be extended to a longer "word".
Anyway, I don't think I can be of any help much.
What you additionally can try is set the Device in the NOS1 Driver Control panel to "2 channels reduced". If it then works it must be something about the 4 channels. And when you're at it anyway, why not set the Sampling Rate to 44100.
From all this you could learn whether it's bandwidth related.
Tore
« Reply #198 on: December 02, 2012, 06:26:39 pm »
Peter, this is the text : Driver IRQL not less or equel
What does that mean?
I have tried the two things you suggested but it was no succsess.
Tore
« Reply #199 on: December 02, 2012, 07:11:00 pm »
Hi Tore - Nothing I can do anything with. Something with an "interrupt" not working I'd say.
Not that I would *really* like you to do it when you are not confident with it, but did you install the latest motherboard drivers ? (I don't think I would like to do that in such a situation where actually all was right (outside this of course)).
PS: You can always feed this message to Google and get an idea about what to do, especially for those (people) who could solve it. Btw, change your "equel" to "equal".
Tore
« Reply #200 on: December 03, 2012, 09:38:52 am »
YES, it is working with this driver : http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Renesas/Renesas-Electronics-uPD720201-uPD720202-USB-30-Driver-30200.shtml
And all my drivers is updated with this program : http://driverwhiz.com/
But i have a new problem: It is a load crack when i start playing. The problem is there only with Phase Alignment on and with NOS1 connected to USB 3.0
This is the 4 port USB 3.0 card : http://www.ebay.com/itm/Fullshop-BUFFALO-IFC-PCIE4U3S-USB-3-0-PCI-Express-Interface-Card-4-Ports-/121023941179?pt=LH_DefaultDomain_0&hash=item1c2d96ca3b
Tore
« Reply #201 on: December 03, 2012, 01:36:51 pm »
Ha !!
Very interesting. I say this, because apparently you didn't have this problem before while you know have it, PLUS others have this problem as well. Notice though that to me this seems not to be a particular USB3 problem, but a driver problem (with the notice that USB3 can do USB2 just the same). Anyway :
Especially for this the "After SFS Rounds" setting was created in XXHighEnd. So, set that to 1 and your problem will be over. BUT :
Think a little about the influence of this. So, when your SFS is very high (say in the 400 range) it will take 45 seconds or so before Phase Alignment engages, and this will not be what you want or like.
You can watch the Wallpaper Coverart for when Phase Alignment engages (watch for the *~* to appear instead of _~_).
But hey, good that you solved it !
« Reply #202 on: December 03, 2012, 05:02:58 pm »
Thanks for the link Tore. I had some issues this afternoon using a different PC with different USB3 board and got blue screens as well and no way to get the NOS1 running.
The updates drivers work just fine and have solved some other issues as well!  Happy
Tore
« Reply #203 on: December 12, 2012, 07:50:28 pm »
Hi Peter!
With the  "After SFS Rounds" on i don`t have the load crack when i start playing.
But sometimes (to often) i have this cracks when i listen to music.
When i turn off Phase Alignment ther is no cracks.
Tore
« Reply #204 on: December 12, 2012, 10:42:37 pm »
Tore,
Think like such a crack is just an interruption of the stream. So, it stops for a brief period. When you didn't have this before it must be dedicated to that interface cards and  something is wrong with it. "Wrong" is a tough word, because with some PC I have it myself that one time right after playback has started, and I ave no clue how to solve it (yes, that SFS Rounds but this is a backdoor solution).
« Reply #205 on: April 14, 2013, 11:36:24 am »
Removed a post regarded as spam.
ptustephen, please refrain yourself from promoting general items with no merits other than possibly being cheap.
