November 22, 2024, 11:27:58 pm *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14  All
Author Topic: PCIe USB 3.0 host card  (Read 237480 times)
0 Members and 15 Guests are viewing this topic.
praphan
« Reply #180 on: November 19, 2012, 10:08:35 am »
Hi Tore,
This card should be fine since it is driven by NEC/Renesas driver. I think you can find a cheaper two ports card which works well too. A number of us here uses TeckNet or Star Tech PCIe USB3 cards.
Praphan
Tore
« Reply #181 on: November 19, 2012, 02:33:48 pm »
Thanks Praphan!
Tore
« Reply #182 on: November 19, 2012, 02:43:18 pm »
Hi Tore,
This is the one I use and the sound is beatuful and no problems at all: http://www.amazon.co.uk/gp/product/B004S0Y9FK/ref=oh_o02_s00_i00_details
There is other four ports card but read the reviews: http://www.amazon.co.uk/TeckNet-USB-Ports-Express-Card/dp/B005LV3Z0A/ref=sr_1_3?s=computers&ie=UTF8&qid=1353332152&sr=1-3
Tore
« Reply #183 on: November 19, 2012, 03:21:40 pm »
Hi Juan!
I have seen that 4 port card and it have wrong chip
I want 4 ports for NOS1, USB key (playback drive), HDD (music) and USB bluetooth (keyboord/mouse)
Tore
« Reply #184 on: November 19, 2012, 03:27:03 pm »
Hi Juan!
Tore
You could use a powered USB 3.0 hub for the Playback drive (key) or use the RAMDisk as Playback Drive. Don´t need more than 2 USB 3.0 ports and the hub. Now I´m only using one port, the one for the NOS1, and the sound is fantastic.
« Reply #185 on: November 19, 2012, 04:36:25 pm »
Allow me Juan,
This may be a bit too fast, that "or use the RAMDisk". It is an option of course, but it should be an option to choose from at all times. Not prohibit yourself from it (by choosing a certain combination in advance).
But I'm sure that's how it was meant ! Happy Happy
« Reply #186 on: November 19, 2012, 04:56:58 pm »
Allow me Juan,
Yes Peter, you are right, must be an option open to both possibilities. Sorry if I haven´t expressed myself correctly. As you can see in my signature I can use both, the external hdd and the RAMDisk. The USB 3.0 PCIe I have has only two ports, when I need more ports for whatever reason I use the USB 3.0 hub. At this moment I´m using only the RAMDisk, that means that I only use one port from the PCIe as my music is in an internal hdd (and in an internal SSD for Galleries). I´m trying to experiment with the most simple possible setup, that means as less possible devices connected and the result so far is a very clean sound.
Tore
« Reply #187 on: November 19, 2012, 05:02:33 pm »
Many thanks, Juan
Tore
« Reply #188 on: November 28, 2012, 11:57:40 pm »
The Buffalo USB 3.0 PCIe card is inside my PC now and is working with everything except with my NOS1 USB ??
This is the card: http://vr-zone.com/articles/buffalo-launches-4-port-renesas-based-usb-3.0-card/13741.html
When i choose Phasure USB Audio Control Panel the screen is getting blue and with this text: Windows have  found a problem and to prevent damage the PC is shut down .
The same is happening when i try playing with xxhighend.
Can someone help me with this?
Tore
« Reply #189 on: November 29, 2012, 12:39:16 am »
Tore
Tore hi,
Sounds like it could be the USB 3 driver version that you have for the card. When I first tried the 2 port card the driver that came with the card would not drive the NOS1. For the two port Renesas chipset this driver version works and sounds good.
Renesas USB 3.0 Driver 2.0.34.0
Might be worth finding a copy and trying this assuming it will drive the 4 port card as well. If it won't drive the 4 port card try alternate version for the four port chipset. With luck this will get you going .
« Reply #190 on: November 29, 2012, 09:29:50 am »
Tore,
In my experience, when such a message appears, it is just true what it says, and things are electrically wrong (too much current flowing somewhere).
What I can't tell is whether this is a bad card or just a "bad" driver or whatever.
When you say "it works with everything but not with the NOS1" this doesn't tell much, because the NOS1 driver runs at a higher speed (remember, this is net 32/705.6) which will automatically imply higher currents. Otoh, when this is really an USB3 card it should be capable of much higher speeds than what the NOS1 implies.
Do notice that it is not guaranteed at all that a random USB3 card is fully compatible. A first thing it may imply is a higher latency. This is a bit in the realm of what Nick advised you -drivers which may play a role.
When you can go into the NOS1 driver panel, you can try to set the (buffer) latency to 16ms and see whether that helps.
Anyway, regard the message as serious and possibly you can talk about that with Buffalo. And may it be important : the NOS1 driver is 100% USB class 2 compliant.
Tore
« Reply #191 on: November 29, 2012, 10:59:58 pm »
I connected NOS1 to the PC with USB 2.0 just to set latecy to 16ms.
Then a was getting a little longer. Nothing happend when i choose Phasure USB Audio Control Panel .
But when i tried playing music i got this message: Set State (pause) error on pin.
I have tried Nicks driver, with that one nothing works.
And i have tried to other drivers, same message :
Windows have  found a problem and to prevent damage the PC is shut down.
Tore
« Reply #192 on: November 29, 2012, 11:05:15 pm »
After that first time with latency 16ms i get the same message with this setting to: Windows have  found a problem and to prevent damage the PC is shut down.
When i connect NOS1 to the USB 3.0 port i get the normal green light inside NOS1
Tore
« Reply #193 on: November 30, 2012, 10:22:42 am »
Hey Tore!,
Sorry for being so tiring repeating the same thing again. If I were you I´d buy the PCIe card that I recommended in a previous post, the same one also others use here, it is only 9GBP and works perfectly with the MSI Big Bang-XPower II Renesas USB 3.0 Driver 2.0.34.0 that you can download here: http://drivers.softpedia.com/dyn-postdownload.php?p=145471&t=0&i=2
Try it and if it works in your computer at least you´ll know that the problem is in your Buffalo PCIe and not in the computer.
« Reply #194 on: November 30, 2012, 10:25:54 am »
Tore,
From your description now, all I can say is that it's not a "too much current needed" problem (this could have been the case, but not so anymore now).
Under this message "the PC is shut down" etc., there will be a word in capitals on a separate line. What is that word ?
