November 22, 2024, 07:07:59 pm *
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14  All
Author Topic: PCIe USB 3.0 host card  (Read 237453 times)
0 Members and 13 Guests are viewing this topic.
« Reply #135 on: April 05, 2012, 08:14:31 am »
Well, they certainly sound different. The mobo USB3.0 port (ASMedia driver) sounds 'softer' and in a way 'sweeter'. But everything is perhaps a tad too 'rounded off', though this makes for a very pleasant and easy-to-listen-to sound.
It is here where I started to find myself in deep troubles and had to find out what was the cause (referring to my earlier post). Some albums, seemingly from a certain age, lacked all the highs imagineable. Example : Night at the Opera (Queen).
I am not sure yet what the real cause is with so many tweaks around, but one part of it is an SFS of 280. But, this co-operated with something else you don't have (yet) and I can't be 100% sure this really is related. However, I start to see a line in some things. So, for fun, try the SFS=280 (Q1 at 30 for sure) and play that album which of course everybody owns.
Somehow with USB3 this seems to have super impact.
If this works for you (all highs lack -> all cymbals very far in the background) it could be the perfect setting for classical.
« Reply #136 on: April 05, 2012, 08:18:20 am »
I don't think I or anyone else ever said something stupid like this. But since USB3 I suddenly have these kind of thoughts, and without notice I even wrote it now. sorry
(meaning : since when is it the idea to use "processing" of any kind to tweak for music types ?? -> should be wrong)
stefanobilliani
« Reply #137 on: April 05, 2012, 03:43:34 pm »
Very good point . Of course that "should" be wrong . Some people ( or fiew ) in the music recording places started to understand that .  Happy
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
stefanobilliani
« Reply #138 on: April 05, 2012, 03:59:08 pm »
Hi Nick, thanks for this. After trying a few things, I stumbled upon this version of the driver myself, an hour or so before I saw your post. In any event, it has done the trick. Everything now works as expected (see attached jpeg).
And the sound? Well, very, very nice indeed.
The Z68 mobo here has the same driver 2.0.34.0  , and after the reorganizing of some sequence of installations , it works very very well also . Without the need to disable USB 2 and Lecacy .
I mean it , very very well .
Now listening to SFS=280 , Adaptive mode , Buffer Size = 4096 , Clock Res = 15ms as Peter suggested for fun .
For me is quite exellent . And even if I do not own the Queen record mentioned ,I seem to recognize the effect ...
But I was already a "fan" of the High Buffer size :-)
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #139 on: April 05, 2012, 07:17:12 pm »
Do you use a Molex to power the card? and if so does it make any difference to SQ?
Not currently using the Molex power input. But might try this later this evening, once the kids are asleep. Will report back as soon as I've tried it.
« Reply #140 on: April 05, 2012, 07:32:08 pm »
The card I have has SATA power connection. As far as I can see the chipset is powered from the PCIe bus and the aux SATA power is there only to provide for the higher spec inline current delivery of the USB 3 standard. When I hooked the SATA power up to the pc ATx supply to try it if anything sound had very slightly more edge to it. I guess this could be the effect of connecting the SMPS relatively directly into the NOS via the USB +5v in line supply.
Regards Nick.
« Reply #141 on: April 06, 2012, 11:33:12 pm »
With the PCIe USB3.0, I found Scheme 1 (thanks Nick) and SFS=470 sounds good. Right now, my preference is with the PCIe USB3.0. That clarity is just addictive.
I think these settings adress most of my reservations about the SQ of the PCIe USB3 card. I've been searching in bios and os, but it was there in xx all the time (i did correct some of the other settings though).
The subdued highs that Peter mentiones above have been partly the cause of my search, now they seem to be right again.
Thanks!
Disabeling the left over USB2 controllers (chipset and separate) in the device manager does add a bit to the clarity and experience. Unfortunately if you forget to swich them back on before shut down, the next boot will stall somewhere in the process. You will have to restart to the 'last known good configuration'.
Fwiw I rebooted five times in a row as advised for a cure for reboot related issues on the windows support forum. With the new settings and fresh situation the cpu graph in the task manager looks much more  the usb2 one. Not completely the same, but much more alike than my previous posting.
Regards, Coen
« Reply #142 on: April 07, 2012, 05:46:38 am »
Could you pls give me the link to procure a 5m USB 3.0 A male to A male cable. Neither Amazon or e bay have a 5m length.
stefanobilliani
« Reply #143 on: April 07, 2012, 09:10:03 am »
Hi all ,
In the mobo USB 3 set-up , after the manual reinstall of the Renesas I have found a little Host Controller gui -attached below- , that behaves strange . Infact , when " disabled USB 3.0 power management functions" is checked the system won't go to minize OS anymore and will have to chose a restore point back in a time to let XX High End minimize the operating system again .
It's strange also because for a while I thought that this check allowed to remove all the clicks that was there between the playlist reproduction , and the sound was very very smooth and detailed . Well , just with the full OS .
s
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #144 on: April 07, 2012, 09:53:53 am »
scratching
But what about going into Minimized firsrt, and *then* disable that power management ?
Or does that force you into a reboot which next is Normal again ?
stefanobilliani
« Reply #145 on: April 07, 2012, 09:56:37 am »
Hi all ,
s
I may add that if that thing is checked when the minimize OS is working , it will work ( work? ) , and reboot still in minize OS and so on , until the decision to go back to the normal state ( no minimize OS ) . At that poing there will be the beginning of this post: the only way to go back to minize will be the restore .
Thanks and regards
Stefano
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
stefanobilliani
« Reply #146 on: April 07, 2012, 09:58:47 am »
when " disabled USB 3.0 power management functions" is checked the system won't go to minimize OS anymore
scratching
Hi Peter ,
I was answering your question while typing  Happy
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #147 on: April 07, 2012, 10:02:57 am »
Haha.
But do you happen to know what happens when you swap the state of that power management back and *then* reboot into Normal ?
Not that this should be your procedure, but when this is confirmed I may be able to do something about it. May, because at this moment I have no clue what happens.
stefanobilliani
« Reply #148 on: April 07, 2012, 10:07:53 am »
Haha.
Well , not yet . But...
when I do the swap , it says " must reconnect all your devices for the new settings " . I guess I will try to reboot instead .
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
stefanobilliani
« Reply #149 on: April 07, 2012, 10:41:55 am »
Haha.
Still do not know what happens , but I did try this : went to minimize OS , swap the USB 3 management to "disabling" . The from the same state , "enabled" again .
Back to Normal state OS . Confirmed that the disabling is uncheck . Try again Minimize OS , no effect : the OS stay normal .
For now I decide to let the management enabled .
Grazie
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
