November 23, 2024, 03:48:32 am *
Author Topic: How to reconnect LAN ?  (Read 5807 times)
« on: March 03, 2012, 05:43:04 pm »
I was wondering if it would be possible to use unattended mode - but with reestablishing the network after ?
My problem is that I normally connect to my musical desktop (or laptop) from another place (either a general purpose desktop or an Ipad), but as soon as the unattended mode is on, I have to connect my USB keyboard and/or USB mouse to restart the computer and disengage the unattended mode...
Possible maybe ? Or eventually ?
« Reply #1 on: March 04, 2012, 06:50:36 am »
Hi Alain,
That will be solved in 0.9z-7 by this : XXHighEnd Remote Control.
(which is sort of what you are doing already, but can't work before 0.9z-7)
« Reply #2 on: March 05, 2012, 01:09:10 am »
Thanks for the link. I saw it, but since I use to work with ThightVNC, I was not really in that "remote thing", well not the way it seems to be asked in the link.
But no matter how it will be done, I will be happy to comply when it will be time for it. Happy
And the interface looks exciting too ! Happy
