« on: March 03, 2012, 07:28:41 pm » |
On every recording, try it. IMO one way or the other will sound better depending on the recording. Peter's player is so resolving I can tell in an instant which phase sounds better for a particular recording. The music will be either sucked away from me or be pushed forward. Of all the tweaks we talk about, this is a big one that I think some forget. Discuss, do you use the phase button? I've gotten into the habit of doing a quick 10 second listen at first to see if I need to switch it. [Alt I] is your friend.
0.9z-8-3a WAV/CUE files on HDDs via MB FW400>; Win7 pro ttp://www.phasure.com/index.php?topic=352.msg4021#msg4021); [XXHighEnd player Qs 7, 0, 0, 0, 0; eng 4; adaptive; scheme#3; player priority low; thread priority realtime; clock res 5ms: SFS 420  dac is 24/192 w/32bits; Play Unattended; Stop Services ticked; Wallpaper & Show Back ticked - Mirror Image unticked; Start Engine unticked;garbage collect ticked; copy files to XX-drive; *quad arc prediction upsampling*: straight contiguous:>PCI FW800 card>Fireface 800 DAC [latency 2048 samples for 176.4]; usb/ethernet/mb audio shut off @ MB
xp9433
« Reply #1 on: March 04, 2012, 05:55:19 am » |
Agree with you whole heartedly. Option for absolute phase inversion is a must for me, and has been for over thirty years. May I please ask what speakers you have Severed? Thanks Frank
« Reply #2 on: March 05, 2012, 07:15:33 am » |
A gentleman here in San Diego, CA designed them and PBS Speakers/audio built them. His company is Quintessence. The speakers are named Stealth. He had a pair of Wilson Reference and designed the Stealth using the Reference... well, as a reference. heh Mine are piano black and a different driver complement. I use a Pass electronic xover. I also use 3 Sunfire subwoofers to catch as wide of range of low freqs at the listening position... i guess I kinda like power and loud oops.
« Reply #3 on: March 05, 2012, 09:00:20 am » |
Already many years back, when the Inverted Phase was introduced (both of you were there already), I tried to auto-determine how the Absolute Phase must be (per track). I failed. The code is still in there (inactively), but maybe today I am more smart than back then and now I can do it ? I feel the urge anyway ...
xp9433
« Reply #4 on: March 05, 2012, 09:24:52 am » |
Severed The Stealth looks really fantastic. I see it got great reviews/feedback also. The reason I asked about your speakers is that usually for someone to be consistently senstive to/able to identify absolute phase their speakers are usually also phase coherent/aligned, that is, starting with all drivers being connected with the same absolute polarity. Do you know if this was a design choice for the Stealths? Cheers Frank
xp9433
« Reply #5 on: March 05, 2012, 09:48:18 am » |
PeterSt Automatic detection of correct absolute phase/polarity would be a first anywhere.
Do you really think it is possible when in many cases individual instruments in multi-microphone recordings can be out of absolute phase with each other? That is why choosing which absolute phase setting suits many multi-microphone recordings, might be individual listener preference. However, with simply/well miked recordings auto detection could be fantastic!
Then you have the issue of overall system absolute phase, so you might need an auto reversal option (for all recordings) to suit the system absolute phase structure as well as the recording? Am I making sense?
Frank
« Reply #6 on: March 05, 2012, 10:25:51 am » |
Hey Frank. You make perfectly sense in everything. This includes the varying absolute phase per microphone etc. But, this would just be a matter of taking your chances, and since this won't be the "normal thing happening", the guess would be a good one often. But it is about this "guess". Btw, I think we (or I) talked about this ever back (when I failed), because there is no real means to detect the absolute phase. Well, I thought there was, but it didn't go by the simple means I had in mind. But as said, maybe I am more smart today and maybe I by now can use some other means to find out ... Then you have the issue of overall system absolute phase, so you might need an auto reversal option (for all recordings) As how I set it up so far, it just goes per the track. So, each track is analysed first, and depending on what's found the absolute phase will be set ahead of the track (so it may change per track). That's not a big deal. Btw, in the mean time you must remain to be able to invert whatever is found. So, the overall setting. This is because your system may incur for it (an inverting DAC etc.). Regards, Peter
« Reply #7 on: March 06, 2012, 05:12:34 am » |
What can I say... the speaker is multi-driver and not really a point source speaker. Tom/Quintessence paid attention to the phase of all the drivers of course and the three upper boxes are movable to help alignment/height... anyway, all I know is I can hear a significant difference in the sound stage presentation when toggling between the two absolute phases.
« Last Edit: March 10, 2012, 05:17:35 am by SeVeReD »
« Reply #8 on: March 06, 2012, 05:17:38 am » |
Frank
Pretty much this. On some recordings it really is a preference of how you want to hear a mixed bag of phase. I usually end up liking one way better than another... just why I say, check out each of your rips. Very few times I don't have a preference.
xp9433
« Reply #9 on: March 06, 2012, 08:45:39 am » |
Severed "I usually end up liking one way better than another... just why I say, check out each of your rips. Very few times I don't have a preference."
I totally agree. I even adjust for absolute phase on my Ipod (wav)/FiioE11 headamp/Etymotic headphones, when I am out walking!!! (The Fiio has a gain button which changes absolute polarity - and I adjust volume to suit). Somewhat excessive I know - but for me it has to be right.
Frank
« Reply #10 on: May 27, 2012, 07:41:20 pm » |
Is absolute polarity a thing you intend to include in your incoming version ?
Though there are some lists around, none is exhaustive and I can understand why, I am still unsure about the perceptions I should have between a song in absolute polarity and one in reversed ?
« Reply #11 on: May 27, 2012, 07:54:24 pm » |
Salute Alain  As (I think) I said in the previous post in here, I must first be somewhat smarter than I am. But who knows that happens. Anyway, not for 0.9z-7 ... Peter
doublelife
« Reply #12 on: March 18, 2016, 10:30:48 pm » |
Can we toggle the 'invert phase' button on and off during playback or must it be set one way or the other before hitting 'Play' ?
PC i7 / W10 10074 (x64) / hyperthreading ON (12 cores) / 32GB RAM / XX - OS on separate dedicated 256GB SSD - XXHighEnd: 2.03 / Engine#4 Adaptive / 4096 / Q1=14 / xQ1=10 / Q3,4,5=0/1/0 / SFS=4-120 / Straight Contiguous / Clock Resolution = 1.0 / Scheme 3-5 / 16x Custom / Peak Extend = OFF / Unattended / Minimize OS / Phase Alignment = OFF / XTweaks = 43, 100, 1, 1, 1 > 24/768 NOS1a 75B async USB DAC driver v1.0.4 1ms > KGSSHV Carbon amp > Stax SR-009
« Reply #13 on: March 19, 2016, 11:15:48 am » |
Hi Paul,
At the moment it is so that it requires a sequence (for Unattended), like this :
Alt-I Alt-E (Pause) Alt-P (Play)
So this interrupts the music.
I my view it can't go without a pause in between because it would imply a large(r) DC change "blob". Thus, when the music plays a (bass) wave which coincidentally is at the top of the voltage headroom (say +5V) then the one-step inversion makes that -5V and with a "blast" this step is taken. Maybe in practice this is doable, but I never tried to make it ...
Regards, Peter
hudesigns
« Reply #14 on: April 21, 2018, 04:29:21 am » |
Hi Peter, It's been 2 years since last post on this topic. But I find it interesting. In Tidal MQA, I found this fine vintage album. To my ear, it needs IPhase ON. It would be great to hear others opinion. Best, ZH https://tidal.com/album/77641992
XXHighEnd PC -> I5-4460 (4 cores), @800Mhz, 24GB, Windows 10 Pro 64 bit build 10586.0 - Windows system, XXHE and XXHEdata on M.2 SSD on MoBo - Other temp folders on 2.5" internal SSD / XXHighEnd 2.10c, music on LAN / Engine#4 Adaptive Mode / Buffer = 1024 / Q1/-/3/4/5 = 11/-/1/1/1 / Q1Factor = 1 / ClockRes = 1ms / SFS = 12.19 (max 12.19) / Memory = Straight Contiguous / Include Garbage Collect / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / UnAttended / Stop Desktop, Remaining, WASAPI and W10 services / Keep LAN - Not Persist / WallPaper Off / OSD Off / Running Time Off / Minimize OS / XTweaks : Balanced Load = 49 / Nervous Rate = 10 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Custom Filter second High 705600-> USB3 from MoBo -> Modified USB3 "Y" cable -> 32/384 async USB DAC iFi iDAC2 (in bit-perfect NOS mode) powered by battery--->
