April 19, 2025, 06:14:25 am *
Author Topic: Another Wish: Balance Controle  (Read 4826 times)
« on: February 19, 2012, 09:00:57 pm »
Sometimes I have the feeling that the sound is comming most of the time from one side(channel). The level of one channel is higher then the other. I think it is CD dependent. A Bad mix probably. Is it possible to implement balance control in XXHE? Do CD's alway's have the same level in both channels? Is it possible when you normalize the volume, you do the same with both channels (same output level). Normalizing Balance. What do you think about it?
Johan
« Reply #1 on: February 20, 2012, 08:09:17 am »
Hey Johan,
This can only go with those ~1.5dB steps, or otherwise the sound will be not good. This is about the way XXHighEnd's volume works. So, not the best idea ...
