November 23, 2024, 02:23:08 pm *
Author Topic: Ok, everybody, it's REEEEEBOOOOOOOOOT time!  (Read 8043 times)
« on: February 14, 2012, 12:43:23 am »
My dedicated music PC has only 1 duty: Carry my music and running my XX player.
I keep it on 24/7. It is connected to the internet, but I never use it for surfing on the net. Except when downloading XX updates.
But it does perform some automatic antivirus upgrades and security stuff on my OS. I guess this is done from time to time (I let it run in automatic update mode regarding the Windows security stuff).
Anyway, yesterday I discovered a suboptimal SQ in my system. -A kind of hardening in the upper mid range, adding some “glare” and (too much) forwardness on piano, especially.
Today I rebooted the PC and voila!, back to normal. SQ now more homogenic and neutral. I can play louder without fatigue.
-I guess from time to time we have to reset our PCs and let them empty “some sh*t” or whatever happens.
« Reply #1 on: February 14, 2012, 09:06:32 am »
But why do you have it connected to the Internet then ? I mean, don't you have the LAN shut off (in XXHighEnd) ?
Further ... yes, that would be my idea too. In my case a boot session usually doesn't last 2 days so it's alright automatically. But otherwise I would reboot explicitly once in the x (?) days ...
« Reply #2 on: February 14, 2012, 08:10:00 pm »
Hi pedal,
GREAT! That way to use the PC is in my opinion what XX/NOS1 deserves. On the other hand if you only use Internet to download XX updates why don´t you connect to Internet just to do it?
Again, if you only use internet to connect to the XX web site why don´t you forget about antivirus and uninstall it.
I agree, but I´d say that it is even better if you shut off totally the PC for a while. I do it every two or three days and the sound seems cleaner. That´s at least my experience.
« Reply #3 on: February 14, 2012, 08:20:47 pm »
When rebooting doesn't reduce the glare enough, I would add defragging the drive XX is on as another way to reduce "glare" when it appears.
