November 23, 2024, 11:52:15 am *
Author Topic: Play settings for M2Tech Young DAC  (Read 11001 times)
jrocha
« on: January 28, 2012, 08:33:20 pm »
I have a M2Tech young DAC, does anyone have suggestions for the settings of XXHighEnd . I tried the up-sampling to 384kHz+ arcpredicted in KS mode but the sound seams a little compressed.
Thanks
JR
Windows 7 HomeP 64bit / P6100 2GHz / 4GB RAM / music on SATAII  => XX V9z-6-1c / Engine 3 KS/ adaptive mode / DAC is 32 bit 384kHz / 32 bit (17-32 bit rev) / XX buffer 1024 / clock res 10ms / Q1,2,3,4, = 30,0,0,0 / unattended / SFS 300MB mixed contiguous / Threadprio RealTime / Playerprio Low /  no upsampling/Arc Prediction off/ Minimise OS / Peak Extend off / Phase invert off => M2Tech Young DAC => Electrocompaniet ECI-1 => Triangle Antal ES speakers
mrmondegreen
« Reply #1 on: January 28, 2012, 11:53:44 pm »
Try setting an SFS size that allows you to use 'Straight Contiguous'.... you may end up with a size that's much lower than you are currently showing in your signature.  I find that using the Mixed modes muddies things "significantly".
Have you've noticed a difference between 44.1k- and 48k-based playback?
Chris
2013-04-15 (0.9z-8e) Windows 7 Professional 64bit SP1 [binaries on SSD, data on 7200RPM HD], Intel C2D E8400, 8GB DDR3 / Engine#4 Adaptive Mode / Q1/Q1x/2/3/4/5 = 8/2/0/0/0/0 (Dev.Buffer = 3072 / ClockRes = 0.5ms / Straight Contiguous / SFS/Max = 2.0/2.0 / Playerprio = Low / ThreadPrio = Real Time / Scheme = 2 / Minimize OS = On / 4x AP+PE / ** XTweaks (Standard Rez.) : Balanced Load = 54 / Nervous Rate = 3 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 0 / Time Performance Index : Optimal ** ==> AudioQuest Diamond USB ==> M2Tech Young DAC (32 bits / v7-1 W7 drivers)
2014-02-22 (1.186a) Windows 7 Professional 64bit SP1 [binaries on SSD, data on 7200RPM HD], Intel C2D E8400, 8GB DDR3 / Engine#4 Adaptive Mode / Q1/Q1x/2/3/4/5 = 6/2/0/0/0/0 (Dev.Buffer = 4096 / ClockRes = 0.5ms / Straight Contiguous / SFS/Max = 2.0/2.0 / Playerprio = Low / ThreadPrio = Real Time / Scheme = 2 / Minimize OS = On / 4x AP+PE / ** XTweaks (Standard Rez.) : Balanced Load = 54 / Nervous Rate = 3 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 0 / Time Performance Index : Optimal ** ==> AudioQuest Diamond USB ==> M2Tech Young DAC w/ linear power supply (32 bits / v7-1 W7 drivers)
« Reply #2 on: January 29, 2012, 07:41:47 am »
Young-related settings should be the Octo (8x) Arc Prediction Filtering indeed, but also the choice between "DAC Needs" 24 bits and 32 bits. 24 may sound better. Try this carefully though, because I relate this to the HiFace where this is possible. The Young should be the same, but might not.
Further there are so many other settings and combinations of them. It may take you a few days to get hold of them all (and their merits). A first next thing might be the Clock Resolution. And KS Special Mode with a really low Q1.
And lastly but surely the Minimize OS (and Unattended Playback of course (no UI)).
Hope this gets you going a little ...
Peter (sending welcome greetings just the same)
ivo
Music lover
View Profile WWW
« Reply #3 on: January 29, 2012, 10:15:27 pm »
I was using HiFace original then HiFace MK2, now JKDAC32 which contains HiFace inside. With the latter I switched to Young's drivers as in several forums people have confirmed this way sounds better. I suspect if Young's drivers fit HiFace, HW is "the same". Just renewed my signature, so check please settings of XX there.
Robert
« Reply #4 on: January 30, 2012, 02:03:10 am »
I've upgraded to Young driver and it definitely is an improvement over standard drivers for Hiface.
Stick with that but you need to work slowly through XXhighend settings. It takes time and listening to sort.
Try one setting at a time and give yourself a week unless it is very obvious. I've been running engine 3 for 3 months and only just changed to engine 4.
Bearing in mind that XXhighend can deliver a sound that requires speakers to be repositioned, subs to be recalibrated or equipment short comings!!! etc.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
jrocha
« Reply #5 on: February 01, 2012, 11:52:26 pm »
Thanks for all the suggestions.
I'd start with upsampling to 192 kHz and antimage ON
SFS straight continuous at 10.
engine #4 and KS adaptive mode 4096 buffersize
I like the SQ now, i will follow the suggestions and make the adjustments one at the time and wait to settle down the effect.
Regards
jrocha
« Reply #6 on: February 02, 2012, 08:58:53 am »
This (Anti Image) should give you the worst SQ of everything ...
