April 05, 2025, 01:39:38 pm *
Author Topic: NOS1 SQ to next level possible ?  (Read 31924 times)
« Reply #15 on: January 19, 2012, 11:45:29 am »
Hi Juan,
The NOS1 can process 24/768, so that is what it should be set to (DAC Is). What you use of that is up to you (that rate or lower).
What Jarek by accident allows is an input file of 32 bits, and while the DAC will process it (but will chop off 8 bits), XXHighEnd does not support it. So it can't harm anyway. But it would be correct to say that Jarek defined the NOS1 a little wrongish.
What I can say so far is that setting 32/768 in DAC Is doesn´t sound  worse than setting it at 24/768. Does it sound  better?, I don´t know...it couldn´t be possible but I´m not sure. Placebo?
« Reply #16 on: January 19, 2012, 11:47:57 am »
Juan,
If you feel your NOS1 is still breaking in, it should be about the USB part. In that case bring up the Control Panel before you go to sleep. That should speed it up.
On the other hand, you may not mean this. I mean, I too feel that I still experience improvement and what I recall is that I changed a few boards in my own NOS1 last July; maybe August.
It is quite tough to experience these improvements, and it can only go by means of things you listened to many months back, which today suddenly for sure sound better again.
FYI : I only spend maybe 3 hours per day listening / the DAC being normally active.
I have had a period that I fired up the Control panel an hour before listening, and thought it helped. Or IOW, I often have the idea that the sound isn't at its best the first 30 minutes or so, never mind the DAC is always on ...
« Reply #17 on: January 19, 2012, 11:50:03 am »
Placebo?
Hmm ... I just tried to explain to you that this is only self protection. It doesn't do a thing.
"DAC Needs" sure will make a physical difference, but I don't think it can operate like that (although I have in mind that it can with some setting). Don't try without preamp !!!
« Reply #18 on: January 19, 2012, 12:29:46 pm »
Juan,
Yes, I do, I leave the Panel turned on overnight and I still feel improvements in sound from time to time. About if it sounds better after 30 minutes or not I really don´t know...
Placebo?
"DAC needs" is always in 32bits, I don´t use any preamp at all and I´m aware of it.
praphan
« Reply #19 on: January 19, 2012, 04:52:36 pm »
Hello Juan,
Your signature says you set SFS to 4300.
Is this a typo?
Thanks
Praphan
« Reply #20 on: January 19, 2012, 07:53:38 pm »
Sorry, it is 430.
Thanks, Juan
jarek
« Reply #21 on: January 20, 2012, 08:07:28 pm »
maybe I should start the next topic, but it is still related to my tests to get the best sound and NOS1.
I have i5 660 processor, and if I specify SFS of 200 I have sometimes breakes in music. If I specify 430 I have 1-3 seconds brakes between tracks. I specified 120 and now is OK. I see you and most of NOS1 guys have SFS 400 . Should I upgrade to better processor ?
Also, physically I have 2 core processor, but system sees 4 cores. How many cores does XXHighEnd see ? Is it a metter to switch hyperthreading on/off somewhere ? What should I set then ?
Thank you
Jarek
« Reply #22 on: January 21, 2012, 07:23:31 am »
Hey Jarek,
The higher SFS implies two things :
Higher speed from the line to/from the disc(s) involved;
Higher processor speed.
Your processor is not the fastest, so that can cause it already.
I can't tell about the disc speed (but e.g. a 100Mbit ethernet to a NAS would be too slow for sure).
When you switch off hyperthreading the speed of the one core dealing with the processing of the file will be twice as high. So that helps *if* that causes it. But now other things will be not good (SQ, slow loading of FLACs).
Yes, XXhighEnd utilizes all cores (up to 24 are explicitly supported).
If you take a modern fast i7 (the 2600 maybe), all around it can be build to on par specs. This is nore than core speed alone (memory lines etc.).
If you want to spend more money on it, have a 6 core.
Always use Intel because of the hyperthreading and thus more cores.
« Reply #23 on: January 21, 2012, 02:01:21 pm »
Jarek
Hi Jarek,
I´m testing your 24/192 way of ripping and although I don´t have yet any conclusion about sound I experienced the same breaks in music at SFS430, not in between tracks but in the tracks, not always but once in a while.
If I change to SFS120 then there is not breaks but the sound changes and it´s not so smooth as it is at SFS430.
Anyway, as I have an i7, 6 cores processor with hyperthreading activated and XX seeing 12 cores (6 + 6) and have the same promblem as you I don´t think that the problem is in your processor, that should be fast enough. Maybe it is in the dBpoweramp software when it is upsampling to 24/192.
« Reply #24 on: January 21, 2012, 03:08:57 pm »
Interesting ...
Notice please : You may tend to check with normal 24/192 Hires files, but this is broken in the version you have. Or at least the chance is fairly high that you run into Hires files which actually contain a problem in the header, and which I solved for the version I have here. Or these files don't play at all, or they and up in noise (mighty fast playback) after a minute or so. IIRC this only happens at 768 ( 705.6 ) output; with 384 ( 352.8 ) there's no problem.
Well, I talked a lot about this real problem, didn't I ?
The most logical thing to me would be that the disc I/O is the bottleneck; remember, these files are quite some larger.
The processing is quite the same (it takes somewhat more though), and so it won't be the cpu doing it to you ?
« Reply #25 on: January 21, 2012, 05:26:48 pm »
Rip your favorite CD by using dbPoweramp to Wave and specify format target as 24/192. Play it with NOS1 USB and 32/768kHz / ARC prediction.
Jarek
That is an exceptional idea and I will test it.
On my SYSTEM I hear no advantage with the dBPoweramp  "filtered" files.
The instruments are crystal clear to hear, but the reverberations of the room is missing. So it sounds dead and the emotions are gone. ON MY SYSTEM.
« Reply #26 on: January 21, 2012, 05:59:11 pm »
Well, at least that is what I would expect more to be the case ...
I would have tried it myself by now, weren't it that I am quite deaf on one ear. Never mind which one, one is enough. aggressive
jarek
« Reply #27 on: January 21, 2012, 08:06:40 pm »
I see most of you guys have Clock Resolution in XXHighEnd set to 15 ms, whilst I have 0,5 ms. Truly, in my system it sounds less digital and edgy when clock is 0,5ms than 15 ms.
I have bigger room ambiance and the soundstage with dbPoweramp target set to 24/192 than to 16/44,1. It sounds "richer" then regular rip, more like hi-resolution tracks. Maybe it is artificial, I do not know - I like it more at least with XXHighEnd and NOS1.
I can hear also a difference between Windows 2008 SP2 and Windows 7 SP1 (both 64-bit). I have them on dual boot. I think that sound from Win2008 is more pleasing. I cannot find a better words to describe it. Win2008 has better combination of resolution and emotionality.
As regards to SFS I like setting of 120. It is OK for me, I do not feel it sounds any worse than 430 in my system.
Jarek
