April 05, 2025, 12:48:30 pm *
Author Topic: NOS1 SQ to next level possible ?  (Read 31905 times)
jarek
« on: January 16, 2012, 08:23:45 pm »
YES. Here is my experience, try for yourself and share your impression.
Rip your favorite CD by using dbPoweramp to Wave and specify format target as 24/192. Play it with NOS1 USB and 32/768kHz / ARC prediction. I did it and almost got fiver because of it ! Now I am reripping my favorite CDs to 24/192 to hear them all again !
Peter, congratulation for your work ! Another happy owner of NOS1 is here !
Jarek
« Reply #1 on: January 16, 2012, 09:34:02 pm »
Jarek
That is an exceptional idea and I will test it.
« Reply #2 on: January 17, 2012, 08:12:54 am »
rofl
Hahaha, it was a matter of waiting until someone came up with combinations like this. Not that I *really* thought about it, but is IS an explicit application of the NOS1 of course (all this stuff outboard, nothing interfering with it).
Ok, everybody is going to try this. I will too. But first a question :
I don't know dBPowerAmp and I first wonder whether we are able to do it differently than you did Jarek. So, are there options anywhere ?
Is there a description to how this upsampling works ? (I think in filtering realms).
In any event, thanks for sharing !!
« Reply #3 on: January 17, 2012, 11:33:26 am »
The administrator of dbPoweramp, Spoon, specifically suggests not to upsample while ripping. He believes that for optimum sound quality, ripping should be done same as source.
As a matter of fact, in the early days of CA, I too had ripped Redbook CD to 24/192 & 24/96 & compared the same with native 16/44.1 files. My impression was that the upsampled files sounded bright & digital. In any case they didnt sound better than the native files. Mind you in those days I was using the Empirical Audio, Overdrive DAC.
Besides this I really dont see any reason why this would improve SQ, after all one is upsampling to higher levels (32/706) at XXHE while playback using Arc Prediction filtering, anyway.
« Reply #4 on: January 17, 2012, 12:48:15 pm »
Arvind, you are totally right. But per today's knowledge and usage (of the NOS1) only half. Or maybe not at all.
Where Spoon also is right, today this is about the best means possible to create something out of Redbook which ALWAYS needs a filter. Upsampling is such a filter within itself. Now it just depends on how this filter is organized. And I can tell you : the most stupid ones may fulfill the task the best.
What happens here is that two filters are cascaded; the one from dBP and Arc Predition. When dBP contains a normally "good filtering means" it should fail for a better SQ result.
But this is why I asked about possible documentation and options ...
What's also important to me : When this is Jarek's finding, I believe him, until proved otherwise. I think at some stage I believed your specific findings as well, while others ordered me not to touch the software (for you alone) or otherwise "their" SQ would degrade. Remember it ?
All this little flashback should tell, is that we never should doubt one's findings. Let theories be in the last place.
(when we would be following theories or science, we would end up nowhere ... no)
... and all does not tell that you (Arvind) shouldn't be right on your theory as well; I just agree with that ...
But  know what may happen when Arc Prediction is cascaded with other filters; I have been playing around with that ... for a reason.
jarek
« Reply #5 on: January 17, 2012, 07:14:39 pm »
Theoretical considerations are important, but... try and hear it for your own ears.
My ears tell me that I got MUCH better sound when ripping regular CD by dbPowerump to 24/192 wave and then playing it with XXHighEnd x16 than ripping to native format 16/44,1 and playing also with XXHighEnd x16.
I got nothing but bright sound. The sound is very detailed in a right way. The soundstage is huge, stable and sound is perfect, at least in my system of course.
J.
« Reply #6 on: January 17, 2012, 07:29:42 pm »
Hi Jarek - any chance that you could put details of your system in your signature?
P
jarek
« Reply #7 on: January 17, 2012, 10:36:44 pm »
Sure, just updated it below.
« Reply #8 on: January 18, 2012, 07:43:02 am »
Jarek, is it really so that you don't use hyperthreading (looking at your "4 cores" in your sig) ?
Edit : Ahum fool, you do. But the base of the i5-660 is two core of course. Happy
« Reply #9 on: January 18, 2012, 01:11:00 pm »
Jarek
Hi Jarek, I don´t understand well why you say that you play it at 32/768kHz but in your settings you have 24/768kHz.
What should be the panel setting for Sample Rate, 352.000kHz or 384.000kHz?.
Regards, Juan
« Reply #10 on: January 19, 2012, 07:43:45 am »
As I´m ripping now my cds with different settings and while I wait for Jarek answer, could you tell me please what Panel setting for Sample Rate should be used, 352.000kHz or 384.000kHz? and  if we are ripping at 24/192 which one must be the XX setting, 24/768kHz or 32/768kHz?
Thanks, Juan
« Reply #11 on: January 19, 2012, 08:43:15 am »
Juan,
Maybe I don't understand the question;
You didn't ask before, so what is the reason you ask today ? Or is this only Jarek-related ?
Anyway, input to the NOS1 is always 32 bits (but XXHighEnd takes care of that once you told "Needs 32 bits" (which is the default for everyone).
Next you don't set the output rate directly, but tell how many times upsampling needs to take place (2x, 4x, 8, 16x). So, the input determines it.
But this has always been the case and has always been clear, I'm sure. So I most probably don't understand the question ...
« Reply #12 on: January 19, 2012, 10:53:07 am »
I posted a question for Jarek in the forum and I can see it, maybe you can´t. It is:
Jarek
Regards, Juan
Yes I have the 32 bits clicked in At>16bits the DAC needs, but what I ask is: what is the correct dac setting in XX (DAC Settings) 24bits 768.0KHz or 32bits 768.0KHz?.
I always used 24bits 768kHz and fx x 16 Arc Predict but if I understand well Jarek is using 32bits 768kHz (in XX DAC Settings).
Also what must be the Panel Sample Rate 352.000kHz or 384.000kHz?
Thanks, Juan
« Reply #13 on: January 19, 2012, 11:11:18 am »
Hi Juan,
The "DAC Is" setting you talk about, merely defines the maximum, and it is there for self protection. So, if you define your Altmann DAC (16/192) as e.g. 24/384 *and* you choose for 8x upsampling, something may go wrong with your windows (but more probably an error will follow).
The NOS1 can process 24/768, so that is what it should be set to (DAC Is). What you use of that is up to you (that rate or lower).
What Jarek by accident allows is an input file of 32 bits, and while the DAC will process it (but will chop off 8 bits), XXHighEnd does not support it. So it can't harm anyway. But it would be correct to say that Jarek defined the NOS1 a little wrongish.
The Control Panel is not important, because it will be overruled by XXHighEnd anyway. Set it to what you want and start playback; you will see that it changes automatically.
« Reply #14 on: January 19, 2012, 11:33:49 am »
Thank you Peter, now I´m testing what Jarek said but it´s hard mostly because I think that my Nos1 USB is still breaking in and the changes I feel could be just a matter of this process.
