April 05, 2025, 01:50:01 pm *
Author Topic: Problem with the second track  (Read 17439 times)
« on: January 04, 2012, 11:02:50 pm »
Hi Peter, I have a problem with the second track. After the first track is finished, I receive two messages "No Track given" and "Fail! No Track Data found" . If I turn on again XXHighEnd and select that second track then I have no problem with that track or the following. This only occurs when passing from the first track to the second one.
I´m not sure if I read something about this issue in some posts, sorry but I can´t find it
« Reply #1 on: January 04, 2012, 11:30:21 pm »
Hi, these messages look familiar. I didn't  notice it was the second track.
My impression is that I encounter these only at specific (flac) albums maybe even specific tracks. Sometimes my entire playlist pays without these messages. Rebooting helps.
I will keep track from now on.
Regards, Coen
« Reply #2 on: January 05, 2012, 12:10:21 am »
Hi Coen,
All my tracks are wav and it happens just since a few days ago, never happened before. On the other hand I´m making some important changes in the OS like partitions, besides testing different cd-roms. Maybe some of this has affected the XX configuration. The sound is great though.
I´m not sure yet if it happens with all my albums or only with some.
« Reply #3 on: January 05, 2012, 08:33:39 am »
With Unattended ?
« Reply #4 on: January 05, 2012, 09:11:02 am »
Yes, with Unattendet
« Reply #5 on: January 05, 2012, 04:30:48 pm »
Hi Juan,
Seems totally odd to me. Impossible actually.
If you can copy this behaviour, please post the XX, X3 and X3PB log files from such a situation; wait for the message appears ("didn't start in time") and then grab the log files.
Are you sure you didn't mix XXHighEnd versions (for the XXHighEnd.exe and the remainder) ? You wouldn't be the first one ...
« Reply #6 on: January 05, 2012, 04:48:16 pm »
Thanks Peter. Well, today I played around 10 albums and everything was fine. I haven´t mixed different versions for sure because I´m using the last one since it appeared but I overwrote a couple of times this last version and installed the drivers three or four times when I had to reboot, unplug, etc the computer due to the problems I mentioned with the missing hdd in the bios.
If it happens again I´ll look for those log files (although I did it before once, now I don´t remember where they are, I´ll ask in such a case).
« Reply #7 on: January 05, 2012, 06:37:49 pm »
Switch logging on in advance (like today). You will find them in the TemporaryData folder under your XX folder ...
« Reply #8 on: January 06, 2012, 08:24:44 am »
Sorry, I don´t understand what you mean
« Reply #9 on: January 06, 2012, 08:28:00 am »
I meant : switch it on now, or otherwise you will be behind the facts. Obvious of course ... Happy
« Reply #10 on: January 06, 2012, 08:56:23 am »
Ok, I understand, I´ll post the log files in case it happens again. Thanks
« Reply #11 on: January 16, 2012, 11:31:47 am »
It happens sometimes with me too but not necessarily with the second track only.
Other times I have noticed that a playlist does not start playing at all & a window appears saying " Set point error......pause....." After a reboot all is well.
Both the problems are not very frequent, but next time i see them I will post the log files.
« Reply #12 on: January 16, 2012, 12:20:36 pm »
Hi Arvind,
Is this a literal message ? I really never heard of it !!
« Reply #13 on: January 16, 2012, 06:28:27 pm »
Not literal but something to this effect. Next time I see it I will post the exact words.
jarek
« Reply #14 on: January 16, 2012, 10:19:37 pm »
I got the same problem with second track today. I played 24/192 album, and got message "No track:, or similar, than "The file does not exists" or something. On second trial everything was OK.
Jarek
