« on: December 24, 2011, 02:24:28 pm » |
Happy Christmas to all of you and your families from Juan´s Band http://sendables.jibjab.com/view/iZgS7yUUHVOTksxr
« Reply #1 on: December 24, 2011, 05:18:05 pm » |
Merry Christmas everyone!
« Reply #2 on: December 24, 2011, 05:33:37 pm » |
Thanks Juan.
Happy holidays XX'enders!
« Reply #3 on: December 24, 2011, 06:32:18 pm » |
Thanks Juan. Which one is you in that anime ? From here too, to everybody the best Christmas wishes ! Peter
« Reply #4 on: December 24, 2011, 06:53:46 pm » |
Thanks Juan. Which one is you in that anime ? Peter
Hey Peter, no more champagne before dinner ... I'm the one with white hair and mustache. What other else? Cheers, Juan
« Reply #5 on: December 25, 2011, 01:18:05 am » |
Have a great Christmas and New Year everyone and may the music be with you in the New Year.
« Reply #6 on: December 25, 2011, 11:33:48 pm » |
Best seasonal greetings from Norway, too!
Here is a "postcard photo" of my set up in Christmas dressing. Styling by wife. NOS1 DAC resides behind the left door.
Usually there is a seasonal gift for my system every year. Last year the original NOS1 DAC was my special, arriving just in time for Christmas day.
This year, under the Christmas tree, there were 5 sets of DIY interconnects made from silver/cotton by my friend LMC. I'll give them a run tomorrow.
