November 23, 2024, 03:05:49 pm *
Author Topic: 9-6-1c volume adjustment problems  (Read 4635 times)
« on: December 23, 2011, 11:11:47 pm »
Well changing the volume in my system is unfortunately still unreliable.
Changing the volume whilst playing music usually works after a reboot or restart of XX but runs into problems fast. Well problems... actually noting happens.
The little vertical bar below on the left side of the volumeslider (below #7) becomes green. Eventually XX stops with the 'Engine #4 not started in time' error. I have a hunch that it may be related to pressing the 'next' button.
If this vertical bar is white, usually the volume change occurs.
The work around I use is to pause the music and play again.
This could alle be related to limitations of the modest setup, yet I would really like this to be working with my nos usb now!
regards, Coen
« Reply #1 on: December 24, 2011, 09:56:25 am »
Coen, the volume for Attended never has worked reliably. It doesn't for me either, but "obviously" always when I sit down for it, it keeps on working. Not reliable.
With Unattended it should just work, although it sure is dependend on the performance of your system.
