November 23, 2024, 08:55:06 pm *
Author Topic: Music Root folder does not exist  (Read 8371 times)
Claude
« on: December 04, 2011, 07:47:40 pm »
my music root folder is on C:. I installed XX a couple of days ago and the music root folder was found. Since today the program says that the music root folder does not exist.
So I tried set the root folder to my music root folder again. Started XX again and when I want to search for music I get the same message again.
I have not tried renaming the folder so far.
I can use the win explorer and put tracks into the playlist window (is this the right name?).
I would love not to reinstall.
Best
Claudius
Dec 1, 2011 (0.9z-6-1)
Windows 7 Pro 64bit *SP1* on sd (Macbook Air)/ Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *30*/0/0/0/0 (Dev.Buffer = *4096*) / ClockRes = *15ms* / Mixed / SFS = 400 / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ UnAttended /All Services Off/ *Minimize OS = On* / *Double Octo* Arc Prediction Upsampling /24/768 Phasure NOS1 async USB DAC, Driver v1.0.2 -> Octave HP500 SE ->ADAM Pencil (active) (all PCs Lessloss Signature, Lessloss Firewall, ICs Lessloss Anchorwave and HMS Sestetto, 3 Lessloss Blackbodies)
« Reply #1 on: December 05, 2011, 01:51:30 pm »
Hi there Claudius,
Something must be too obvious for me to grasp;
The Music Root Folder is set in the Settings Area of XXHighEnd. This must match any existing folder. So the only thing I can think of is that you did not do this. Or at least now it is not so anymore.
but ...
I think you are able to fool things by in the mean time selecting another "root" at the bottom (the button with the "..." on it), stop XXHighEnd  and later start it again while in the mean time that particular disk has gone (like an USB etc. disk). It remembers what was lastly used there at the bottom, but if that doesn't exist anymore in the mean time ...
What most probably will solve it for you is explicitly select the folder at that same place at the bottom. For example :
In the Settings you have denoted c:\MyMusic\
In the mean time you selected something else at the bottom, like k:\MyRemoveable Disk\
It is this latter which can't be found anymore (I guess !). Now :
Go again to that "..." button, and select c:\MyMusic\
Now it will be alright again (assumed c:\MyMusic\ exists).
Let me know whether you need more help here.
PS: In the mean time things indeed can get a bit clumsey in this area; I will try to improve on it).
Claude
« Reply #2 on: December 05, 2011, 06:32:20 pm »
I am not in Berlin right now and will check as soon, as I get home.
Thanks
Claudius
Claude
« Reply #3 on: December 06, 2011, 09:21:19 pm »
That solved the problem!
I selected another folder, started again. Then selected the Music folder again and there it was.
Thanks Peter
Claudius
« Reply #4 on: December 07, 2011, 09:54:07 am »
Once in a while I have this myself, but it is always in a situation I am copying something or want to add to Galleries, and at that moment I never can / want to interrupt my "work" - while the anomaly always happens later (at a next startup or something). So, it may come across a bit stupid, but it is somewhat hard to debug because I actually still don't know how to copy the behaviour. But that it can go "wrong" I sure know. Sorry for that ...
« Reply #5 on: December 07, 2011, 12:26:01 pm »
I have the impression you solved this via right mouse click in the left pane: http://www.phasure.com/index.php?topic=1595.msg16723#msg16723
« Reply #6 on: December 07, 2011, 01:47:41 pm »
Hey Johan - Yes, that is what I thought at the time. But the stupid thing is : by "means" of doing something wrong in the first place, that left pane may stay empty because the "music root" can't be found *anymore*, and next what happens is that no rightclick is available there. So, besides it will be hard to guess for newbies that it can be solved like that in the more normal situation (hey, the post you referred to I think shows that I didn't even knew myself it was in there while I wanted to make it) - all should be able to default to the normal set Music Root (in settings) when the "virtual music root" - which is the one which shows at the bottom ! - is not available anymore (removing USB disk etc.).
But there are more situations, like renaming from within XXHighEnd. It just isn't much foolproof at this moment.
Thanks !
Page created in 0.145 seconds with 19 queries.
