November 23, 2024, 02:12:28 am *
Author Topic: Phasure USB Control Panel Sample rate setting  (Read 8947 times)
« on: November 30, 2011, 11:12:00 am »
I´m not sure what´s the sample rate I have to set in the Control panel. I guess that the correct one is 384.000 kHz which is the half of 768.000 kHz but when after setting that value and played music for a while I stop XXHighEnd and open again the Control panel appears the 352.000 kHz setting as the active Sample Rate.
« Reply #1 on: November 30, 2011, 01:34:32 pm »
44.1,  88.2,  176.4, 352.8 Khz
48, 96, 192, 384, 768 Khz
 Wink
« Reply #2 on: November 30, 2011, 05:04:55 pm »
 Wink
Yes, of course...thank you, I was seeing 768 where was 705.6
« Reply #3 on: December 01, 2011, 10:22:36 am »
You don't need so set anything at all there ...
(goes automatically)
« Reply #4 on: December 01, 2011, 11:43:51 am »
Thanks, Peter. I should have paid more attention to the Readme.txt in the Windows install. scratching
