November 23, 2024, 08:33:55 am *
Author Topic: Mixed or straight Contiguous not working  (Read 21328 times)
HAL9000
« Reply #15 on: November 28, 2011, 11:09:57 pm »
Thanks Coen.
I tried it.  It is only accepted without the last "s" in Administrators:
Ntrights +r SeLockMemoryPrivilege  -u Administrator
But still the same "Necessary Privileges...Reboot..." Message,  So no luck yet.
My Windows run 64 bits...
But Thanks for trying to help.  I appreciate it much.
/Jan
*Windows 7 Home Premium 64bit SP1, CORE i7 2600k / Engine#4 Special Mode / Q1/2/3/4/5 = 14(4096)/1/1/1 (Dev.Buffer = 4096)/*ClockRes = 15ms*/*adaptive*/*SFS = 0.40*/ not Invert Phase / Arc predict / Peak Extend / Playerprio = Low / ThreadPrio = Real Time / Scheme 3-5 / 2x Upsampling / MOTU 2408mkIII SPDIF to Metrum Octave DAC -> Abrahamsen main amps -> DALI MEGALINE
HAL9000
« Reply #16 on: November 29, 2011, 09:32:16 am »
 Shocked Holy smokes!  It works now! yahoo
Thanks Peter , Manisandher, CoenP  for your assistance.
What was the trick?
That final "s" on administrators was important...BUT...in Danish the plural of administrator is with "er" in the end...
Typing that like shown here it was accepted, and after a reboot music was flowing instead of the usual warnings.
With straight Contiguous I can go up to 130Mb SFS.  Is that about normal with 8Gb memory?
Now it is time for some serious listening!!   sounds good !
Ntrights +r SeLockMemoryPrivilege  -u Administratorer
/Jan
« Reply #17 on: November 29, 2011, 05:53:59 pm »
Hey hey hey Jan ... good !!
With 8GB you will be able to get SFS=500 (but to my own experience that is too much of it (nerveous sound). 430 works better for me (but it is for the NOS1 and this may make a difference too).
But
You must start playback one time as soon as possible after a reboot to get the higher SFS numbers. After that it keeps on working, until you throw out XEngine3.exe (is the same as using the Off button in the "Q"-panel.
Also, with Minimize OS getting the higher SFS numbers is way more easy (but shut those services down first in the XX-settings first).
PS: Thank you very much for sharing; this will really be helpful for a next one (at least I didn't know this).
HAL9000
« Reply #18 on: November 29, 2011, 06:21:09 pm »
Peter You are right.
After a reboot 500Mb SC is possible.
Everything is good now....and the sound Shocked
At least with 130Mb.  Have not listened long to 500Mb yet.
/Jan
and yes it is quite annoying with those language changes in different Windows versions..
« Reply #19 on: November 29, 2011, 10:15:12 pm »
Hi Jan,
Great to read that it worked! a little persistence gets a long way in computerland.
Now its my turn to get a sfs of more than 35 in my system.... scratching
Regards, Coen
Page created in 0.126 seconds with 19 queries.
