May 11, 2025, 07:50:36 am *
Author Topic: Mixed or straight Contiguous not working  (Read 21923 times)
HAL9000
« on: November 18, 2011, 06:32:32 pm »
Hi Peter.
Just upgraded my pc for XX to work better.  I was hoping to get Mixed or Straight cont working as it did not work with my old pc.
I put in a new MB and processor, plus 8Gigs of Ram just to find that I still can't get other than mixed memory org to work wacko
I do not minimize os or unattended.  I have searched through posts but seem to not find an answer to my problem...
any hints what could be wrong in my setup?
*Windows 7 Home Premium 64bit SP1, CORE i7 2600k / Engine#4 Special Mode / Q1/2/3/4/5 = 14(4096)/1/1/1 (Dev.Buffer = 4096)/*ClockRes = 15ms*/*adaptive*/*SFS = 0.40*/ not Invert Phase / Arc predict / Peak Extend / Playerprio = Low / ThreadPrio = Real Time / Scheme 3-5 / 2x Upsampling / MOTU 2408mkIII SPDIF to Metrum Octave DAC -> Abrahamsen main amps -> DALI MEGALINE
« Reply #1 on: November 19, 2011, 03:46:26 pm »
Sorry for a late reply ...
Let's start with what you perceive from it (hence what "error" message do you get).
Also, if you set the Split File Size to e.g. 12, does it still not work ?
HAL9000
« Reply #2 on: November 20, 2011, 09:36:14 pm »
Hi Peter. Thanks for answering.
I do not really get an error message. Just a new Icon on the process Bar.  It looks like the XX icon but in orange on a black background.  I attached a JPG image.  Even with a small sfs of 12MB and both in Mixed cont and straight cont the same happens. only works in mixed wacko
In mixed I can use sfs of 400 or higher.  Frustrating as  it seems straight cont is the most prefered among users for sound quality...As I recall it on my old pc it said something like "engine 3 has stopped" or similar...
I use W7 home prem SP1.  I copied as much as possible from your setup in the footer of your posts...
« Reply #3 on: November 20, 2011, 09:48:54 pm »
Really, really strange. Never heard about "Mixed Contiguous" not working.
So, if you show the desktop (that little bar at the complete right in the Taskbar) and next click on that black/orange icon in the Taskbar, nothing like an error message shows ?
Ok, what about switching on Logging (at the bottom in the Settings Area) and post the X3 and X3PB logfiles of the session concerned ? Maybe it tells me something.
(the log files are under your XX folder in the TemporaryData folder)
Sorry about your problems, but it must be something strange and new ...
HAL9000
« Reply #4 on: November 21, 2011, 09:45:53 am »
Here the log file.Right clicking on the taskbar icon brings up (see below)...
* XX-20111121-100536.log (15.81 KB - downloaded 545 times.)
« Reply #5 on: November 21, 2011, 01:28:25 pm »
Ok, that is rightclick ... bit normal leftclick ? that doesn't pop up anything ?
Furthermore, I asked for the X3 and X3PB log files. This is an XX log file ... So, if you could perform another small attempt ... Happy
HAL9000
« Reply #6 on: November 21, 2011, 03:54:25 pm »
Sorry I try again.
No, leftclicking makes nothing happen...
Here the hopefully correct files  unhappy
Hope you find the cure  Sad
BR
Jan
* X3-20111121-161838.log (0.47 KB - downloaded 507 times.)
* X3-20111121-133601.log (19.3 KB - downloaded 516 times.)
* X3PB-20111121-133601.log (1.57 KB - downloaded 520 times.)
HAL9000
« Reply #7 on: November 27, 2011, 06:11:20 pm »
Hi Peter.
I know you are a busy person, but did you think of anything that could cause mixed or straight cont. not working?
Could it be soundcard-driver related maybe?
Does Hyperthreading need to be active or not?
/Jan
« Reply #8 on: November 27, 2011, 06:51:23 pm »
Couple of questions: what happens if you minimize the OS and then try mixed contiguous? Also, what is "Console W. Thuneau Arbitrator?" Maybe that has something to do with your problem?
« Reply #9 on: November 27, 2011, 06:59:35 pm »
Man ! I never saw your response ! Sorry about that ...
But now I am more sorry, because I can't make any sense of this (but maybe that is part of the problem). The files seem not to belong to eachother, or possibly you played there afterall ?
I hardly dare to ask it, but could you :
- Set the XXHighEnd settings so that the problem will occur (choose Mixed Contiguous); Put one track in the Playlist Area only (delete the others if necessary);
- Stop XXHighEnd and restart it;
- Start Playback (just Attended).
- Tell me what happens; best would be to wait until you see some sort of message. Tell me that too.
- Do nothing (so leave any message) but now grap the XX, X3 and X3PB logfiles. These will be the last new ones (so whatch the date/times and cause all to be sorted on date/time.
- Post these log files. You can send them to my email address if you want (that will prevent me missing your post again. Happy)/
Thanks !
HAL9000
« Reply #10 on: November 27, 2011, 09:26:28 pm »
Peter Don't be sorry.  I really appreciate you can find time to help.  I did like you said:
only 1 track
stop and restart XX
play....
immediately comes an error now saying  "necessary privileges have been set, Reboot to make them effective.."
after a minute or so another message with:
"engine #4 did not start within..."
Tried rebooting but doesn't help.  It keeps telling me to reboot..    unhappy
I attached the new XX and X3 files.  No new X3PB file was generated since i first started my PC this afternoon...not even after rebooting??
To boleary,  Console is a Host for arbitrator that is an active x-over to split between Quads and subs + room eq.  I will try to disable and see if helps...
/Jan
* XX-20111127-214149.log (6.17 KB - downloaded 507 times.)
* X3-20111127-214159.log (0.46 KB - downloaded 509 times.)
« Reply #11 on: November 28, 2011, 02:47:00 pm »
Hi Jan,
This now sounds totally different from your first post(s). Please look here and see whether is helps you : Mixed / Contiguous Memory.
HAL9000
« Reply #12 on: November 28, 2011, 07:39:11 pm »
Hi Peter.
It seems that the Local Security Policy menu does not exist in Home Premium  unhappy
Is there another way of locking memory pages?
/Jan
« Reply #13 on: November 28, 2011, 08:49:10 pm »
Hi Jan,
Look here: http://www.phasure.com/index.php?topic=1642.0
Just scroll down to where CoenP talks about 'ntrights.exe'.
HTH.
« Reply #14 on: November 28, 2011, 09:36:23 pm »
Please note that this trick worked for the 32 bit HE version. Dunno if this still goes for the 64 bits OS.
regards, Coen
Page created in 10.12 seconds with 19 queries.
