November 23, 2024, 08:50:08 am *
Author Topic: Sound output problem  (Read 4599 times)
HAL9000
« on: October 24, 2011, 11:02:59 pm »
Hi Peter.
Just wanted to try out the 0.9z-6-1 version but found it impossible to get sound to my Console hosting Thuneau Allocator X-over.  Going back to version 09z-6-0 there was no problem.  I use DirectWIRE to route from WDM to ASIO.
My question is, did you change the way XX outputs sound in a way that could cause this problem?  I could choose to stay with version 6-0 forever but I really like how each update improves sound. There is no way of not using Allocator as I use it for my x-over between my Quads and my subwoofers.
I really hope this is a small bug you can fix, and not something that has to stay that way.  Sad
Thanks for the greatest sounding player available in this universe!!
*Windows 7 Home Premium 64bit SP1, CORE i7 2600k / Engine#4 Special Mode / Q1/2/3/4/5 = 14(4096)/1/1/1 (Dev.Buffer = 4096)/*ClockRes = 15ms*/*adaptive*/*SFS = 0.40*/ not Invert Phase / Arc predict / Peak Extend / Playerprio = Low / ThreadPrio = Real Time / Scheme 3-5 / 2x Upsampling / MOTU 2408mkIII SPDIF to Metrum Octave DAC -> Abrahamsen main amps -> DALI MEGALINE
« Reply #1 on: October 24, 2011, 11:27:00 pm »
Thank you for the kind words ... Happy
But I really didn't change a thing !
The only thing is : Don't confuse the various 0.9z-6 versions with eachother. So, if you look in the latest download (0.9z-6-1) only the rar's at the bottom can be combined with eachother; take any other combination and it won't work.
Can that be the cause ?
