November 23, 2024, 09:54:01 am *
Author Topic: What's in a name?  (Read 5257 times)
Eric
« on: October 23, 2011, 09:16:09 pm »
I have a folder called Dvořák. In the folder I have put several albums (folders) like Dvořák - Piano Trio's etcetera.
Now if I click on the Dvořák folder in the embedded Explorer, instead of seeing the Dvořák albums in the middle pane, I get an error message: could not find part of the path.
I solved the problem by renaming (and recreating the corresponding Galleries) the Dvořák folder to: Dvorák. And everything works fine. Please note that the Dvořák - Piano Trio's Album still has the "ř" character in it without causing any problem.
Would it be possible to have XXHE supporting Dvořák ?
But if not, I can live with Dvorák.
Eric
« Reply #1 on: October 24, 2011, 07:35:26 am »
Hi Eric,
So what you are saying is that in
\Dvorak\Dvorak - Piano Trio's\
only the first \Dvorak\ needs the adjustment ?
I suppose clicking on the + to expand the folder is no problem ?
And what happens when the folder is expanded and then you click on one of the album folders like \Dvorak - Piano Trio's\ ? I suppose that will go as wrong ?
Eric
« Reply #2 on: October 24, 2011, 08:11:54 am »
Hi Eric,
Correct.
And it is no problem to expand the folder.
Correct again. (2x)
Now something interesting happened after expanding the folder: the problem disappears. It looks like I first have to expand to have XXHE find the path !?
Eric
Page created in 0.581 seconds with 19 queries.
