April 07, 2025, 01:26:06 am *
Author Topic: Smaller SFS with 6-1c?  (Read 21550 times)
« Reply #15 on: November 09, 2011, 08:14:00 am »
I have a similar problem, I move in between 350 (boleary setting) and 360. I can use all the steps but 357 and I receive the same error window as Arvind (weird that are the same numbers in different position).
« Reply #16 on: November 09, 2011, 08:43:50 am »
Hmm ...
Maybe today you are trying without Minimized OS ? That really makes a difference ...
Maybe you installed some new software which becomes active automatically after booting ?
Windows upgrades ?
I guess you know it, but just to be sure : always start at the higher one, and then go down when you want. The other way around does not work. So, what I (also) say is that you should be able to get that 500 again right after a reboot. Doesn't that work, and it is nothing of the above ? then I'm a bit clueless at this moment ...
PS: Never attempt a first playback which implies a volume normalisation for an album you play for the first time; This will eat the memory in advance.
« Reply #17 on: November 09, 2011, 01:46:06 pm »
In my case it only happens with 357 and with non of the other values. I followed the steps you said, I unistalled a few sofware I had (winrar, adobe and google chrome). No updates at all, Minimazed OS ok and started at 360 and went down, when I get 357 the message is:
Straight Contigous Allocation error 03 - Lower SFS, reboot or choose another type (3 : 87 Total Result = 374341632)
The only thing I could think is that I reinstalled the OS several times and there is part of the previous intallations in some folders as a back up, maybe there could be something that´s disturbing it.
« Reply #18 on: November 09, 2011, 03:12:31 pm »
Sorry, I was wrong, actually works at all even values ​​between 500 and 20 (inclusive) and does not work in any of the odd values ​​between these figures and gives the error message mentioned above (with different Total Results numbers).
PS: I´m not using 6-1c, but 6-1
« Reply #19 on: November 09, 2011, 05:22:45 pm »
Now *that* is a nice one !!
Call that a plain bug.
Cool
Btw, I sent you an email to your gmail address earlier today.
