November 23, 2024, 09:36:57 am *
Author Topic: What to do when W7 has installed several updates after SP-1  (Read 6745 times)
hf
Music lover
« on: October 14, 2011, 05:27:31 pm »
Several people on this forum mention that you should be as close as possible to W7-SP1 and don't install any further updates. I noticed that my automatic update was switched off but not completely: several updates have been performed. What is the best to do (for SQ)? De-install them? And does anyone know how far I should go back?
Or is the influence on Sound Quality only minor (compared to other things)?
Note that I cannot easily install a fresh version of W7 since my Music Vault is an OEM machine. So I want to be very careful...
Hein
XXHighEnd 09-z83a on W7 Pro -16Gb - Ramdisk 4Gb - engine #4 - Adaptive mode - 4096 buffer - Player Low - ThreadPrio Realtime- Qs 30/0/0/0/0 - Qfact 10 - clock 15ms -Tweaks Ultimate - straight cont mode - SFS 120- Max 120 - core scheme 3 - PA on (strength 1) - playback on SATA spinning disc
NOS1 Dac --> LFD power amplifier --> Harbeths monitor 40.1
« Reply #1 on: October 14, 2011, 05:32:55 pm »
Yes, uninstall them one by one. Best start at the last one installed ...
And Hein, notice that it is not only about SQ as such, but merely about that things may start to happen (like hicups because of slowyness) while you won't know why it happens / what is happening.
hf
Music lover
« Reply #2 on: October 14, 2011, 07:32:53 pm »
Ok, thanks,
Wow what a work... I'm back end of May now after 1,5 hour..
 unhappy unhappy
« Reply #3 on: October 14, 2011, 07:34:56 pm »
I hope you set your auto-updates off !
prankster
hf
Music lover
« Reply #4 on: October 14, 2011, 07:54:03 pm »
I'm learning rapidly... Wink Wink
