« on: October 10, 2011, 06:26:48 pm » |
Now I know why Peter went for blue as the first option colour for NOS1 !! so that they would colour key with my new hemp speaker cones - perfect clearly this was the plan all along !!!
« Reply #1 on: October 10, 2011, 08:44:30 pm » |
Hey Paul, Looks really really neat!!  small hint I have bought this mouse and it works great, specially when you do not have a lot of working space. They have made the ball NOS1 Blue!! I have a red ball Maybe i can exchange
« Last Edit: October 13, 2011, 05:30:33 pm by Gerard »
« Reply #2 on: October 10, 2011, 09:25:03 pm » |
Paul, now that you've got the aesthetics right, I reckon it's time for me to come over to have a look... oh and to hear how it sounds also, of course.
Will PM you with possible dates. If there's somewhere safe for me to park, I might drive down in my 'weekend' car, which happens to be pretty close to the colour of the blue NOS1 too.
EDIT: I just couldn't resist attaching a small pic of my pride and joy
« Reply #3 on: October 10, 2011, 10:28:55 pm » |
Hey Mani - the car looks great but I can't help noticing that it is blue and your NOS1's are white!!!! Lots of changes to my system and at last I think that it is sorted sufficiently for your critical eye and of course hearing. I look forward to hearing from you. Oh by the way the car should be OK - mostly wheels stay on cars parked outside  . Paul
« Reply #4 on: October 10, 2011, 11:44:56 pm » |
Paul, I cannot believe those hemp cones are such a good match, you sure you have not been using photoshop  Mani, That's one serious weekend car and looks great in blue. Seems there are a few car enthusiasts around the forum  Nick.
« Reply #5 on: October 11, 2011, 02:13:23 am » |
Ok, I have also something blue (and white) to show you
Too timid, she left
« Last Edit: October 14, 2011, 12:59:41 am by juanpmar »
« Reply #6 on: October 11, 2011, 08:35:00 am » |
Paul, do your new cones have a break-in period that we should avoid?
Juan, you're right - beautiful blue sea and white sand ;-)
« Reply #7 on: October 11, 2011, 09:36:03 am » |
Mani - break in period yes but that is mostly done now and took much breaking in. They spent many hours facing each other with one speaker connected out of phase. A real pain breaking in speakers and hemp cones seem to particularly need breaking in.
P
praphan
« Reply #8 on: October 11, 2011, 06:51:45 pm » |
My NOS1 mimics Mc's "blue eyes".
XX 0.9z-8-3a : KS Engine 4 "Adaptive"; DB = 4096; APx16; Q1/2/3/4/5 = 14x1/0/0/0/0; No Appointment/low/real time; CR = 0.5 ms; XTweaks Ultimate; SC; SFS= 120/120 ; allow format change; unattended ; min OS and stop "all" services; normalized volume usually played at -15db ; peak extension on ; PA off
« Reply #9 on: October 11, 2011, 07:07:34 pm » |
Ehm, Praphan, I hope your equipment is closer to the blue sky than to the blue water at this time. The mixture with blue water doesn't seem a good thing to me, no matter the colour may match nicely ...
praphan
« Reply #10 on: October 11, 2011, 07:58:56 pm » |
Ha ha Peter.....
You know me much much better. I love blue sky with clam wind especially in early morning. This weather condition gets me learn landing the Cessna 172 trainer easier.
As mentioned in my PM to you, my other "crazy" hobby is flying the airplane both in SIM and the real thing.
Water ...... no not now. Thailand is now having a flood crisis in many provinces. And the water is brown , not blue. yak,
Cheers ! Praphan
Flecko
« Reply #11 on: October 13, 2011, 05:20:55 pm » |
Ok, I have also something blue (and white) to show you  You are a Girl and you love your shirt and your trousers?
« Reply #12 on: October 13, 2011, 06:00:40 pm » |
Too much pressure Flecko, as I said she´s shy
Flecko
« Reply #13 on: October 14, 2011, 12:29:18 am » |
....I understand the little envy She looks like a model. But no envy on my side. I know what I have...  The truth is that I wish she was my girlfriend, but she does not like music as much as me and that really is a strong incompatibility Things like that can be a problem. But cheer up. You will enjoy the time much more with a girl, that likes to listen to music with you!
« Reply #14 on: October 14, 2011, 01:17:49 am » |
I'm not sure anyone wants me company to play the same song ten times (or more). This hobby is for loners
Well, once in a while...maybe
