April 12, 2025, 03:01:37 pm *
Author Topic: NOS USB Possible Fault Condition - take care Gain Clone users!  (Read 24678 times)
« Reply #15 on: October 31, 2011, 04:03:05 pm »
Joachim, excuse me, but what does this suddenly come from ?
the Dartzeel amp has a built in DC compensation circuit. The "DC compensation" was disabled by a jumper for a superior SQ ever since, that I did not remember.
I read this thread from Paul (by a hint from you), and my advise  for an operation of poweramps with  similar "DC compensation" choices is as posted above.
The information is for precaution purposes for other Forum readers.
The DC compensation is still disabled at the poweramp for a better SQ.
« Reply #16 on: October 31, 2011, 04:37:44 pm »
Aha ... Ok (of course you don't need to tell me such a thing *first* per se, but it would avoid some misunderstandings I guess).
Ok, thank you for sharing !
One additional thing maybe (I told this to Joachim offline) :
It may be a better solution for particular cases to just switch off the DAC section (Switch #2 for NOS1-USB users). But here too, try what happens in *that* case for a possible louder "plop". And, after the shutdown, you can just switch it on again (but check the DC Offset in that case). Same with booting (when the login screen is there all is safe again for sure).
Of course this all (starting with Joachim's experience) only applies when you don't use a preamp or other means of analogue volume control.
« Reply #17 on: November 01, 2011, 06:37:48 pm »
Hi Peter - for what its worth I have tried turning the NOS1 DAC section off instead of my amp during a reboot and there is nearly as loud a "thump" from the speakers as when I turn the amp off. So now I switch the little volt meters on then watch the offset voltages through the words cut out in the top then reboot with everything switched on - if the volt meters show an offset voltage then I immediately switch off the power amps. Offset voltages do not happen that often (between 1 in 10 and 1 in 20 reboots).
P
« Reply #18 on: November 01, 2011, 06:57:46 pm »
Hey Paul - But are you telling that you see the DC going up, and then you will be in time to switch the amps off ?
Of course you are an athlete, but still ...
haha
« Reply #19 on: November 02, 2011, 06:29:59 pm »
They don't call me "greased lightening" for nothing ha ha
P
« Reply #20 on: November 21, 2011, 08:02:32 pm »
Hi Peter
Routine PC maintenance today and many re-boots. With my GainClones turned off but connected to NOS1 USB twice out of maybe 8 re-boots NOS1 DC offset meters went off scale - both channels. The other 6 re-boots no problems the off set meters continued to show their normal values through the whole re-boot cycle. The point at which the offset meters go off scale is at the exact point that power is switched off in the PC during power down.
This is not a problem for me now that I know what is happening I can manage re-boots so no problems are caused. So this is just for information really in case it is of use for you.
All the best
Page created in 9.718 seconds with 19 queries.
