November 23, 2024, 11:54:15 pm *
Author Topic: Minimized OS (plain W7) Activation Problem  (Read 7788 times)
« on: October 07, 2011, 07:23:47 am »
Hello Peter,
I do have the following “problem”. (The PC is not connected to the NET)
Normally the activation of W7 is certified (status=Windows is activated)
With the minimized OS the status is “Unknown” and the message “This copy of Windows is not genuine” with an oscillating red bar appears on the right lower side of the screen.
According to informations from the “NET” W7 should work without any limitations, but the message with a red bar is annoying.
Any idea which W7 “Service” shall be activated under the minimized OS to avoid ........ ?
« Reply #1 on: October 07, 2011, 07:48:37 am »
Hello Peter,
Just go back (Unminimise) and start again (minimise)
I only had it one time so far.
« Reply #2 on: October 07, 2011, 08:04:40 am »
thank you.
but I went back to the original OS twice already, and the same note appears again. I will see what happens today!
« Reply #3 on: October 07, 2011, 08:19:47 am »
I believe that this note will appear after appr. 30 days again.
« Reply #4 on: October 07, 2011, 09:12:11 am »
Hi hi,
seems to be the running time of the tune during the unattended mode.
« Reply #5 on: October 07, 2011, 09:50:17 am »
swoon
Page created in 0.165 seconds with 19 queries.
