November 23, 2024, 09:48:04 am *
Author Topic: 09z-6 Adding cd's to the gallery  (Read 5702 times)
« on: October 01, 2011, 10:46:54 am »
When i add new tracks i change the path (via library button) to the drive containing the last added rips (F:\). With the right button i add the tracks to the Gallary.
Recently I had in version 09z-5 the message "XXHighend has stopped working" when I add a new cd to the gallerie. In version 09z-4-1 I had this error more frequently. I have made a screenshot of it (See attachment http://www.phasure.com/index.php?topic=1595.msg17105#msg17105).
I didn't see this message in 09z-5-2 but in 09z-6 i sometimes get this message "XXHighend has stopped working" again.
« Reply #1 on: October 01, 2011, 01:34:56 pm »
Hi Johan,
I have just been reading through that other topic you referred to, but I'm afraid this is too much unrelated or changed in the mean time (by me) to be able to "know" what is going on right at this moment. So, I understand that it is about changing the Root in the left pane (I mean, this was the before subject, *plus* I know it is a bit tough to get things right again), but I would not know how to copy the behaviour.
So, when you by accident run into the situation again, can you please try to describe what happened ?
Maybe it is sufficient at first to tell me exactly *when* this message appears (Stopped Working). Could be at dragging files, at trying to change the Path at the bottom, click in the left pane or something ...
« Reply #2 on: October 01, 2011, 01:59:57 pm »
When i add one ore more cd's to the gallery:
1 Selecting the library button;
2 at the bottom i changed the path where i have saved the ripped cd eg f:\music\jazz\
3 then i select the button to select and sort the albums on date
4 i select the cd and do i right click and select "add to gallery"
5 that give me a new menu, where i can choose "select"
6 i now select on c: in the gallerie the jazz directory
7 normaly i see the message one or more cd added to the gallerie, but sometimes it give that message "xxhighend has stopped working". after starting xxhe again i repeat this procedure. Mostly with succes! It go's wrong 2 of 10 times.
I'll hope it is clear now.
Johan
