April 06, 2025, 03:25:11 am *
Author Topic: Best USB cable between PC and NOS1?  (Read 43591 times)
« on: September 21, 2011, 01:55:33 pm »
This afternoon I will become the lucky owner of the NOS1 24/768, returning from upgrade.  very happy
But, what is the "best" USB cable to use?
Can we use any standard low-price cable, or what about the upgrade versions from companies like Wireworld, who provide extra shielding of the 5V carrier inside the USB cable?
Example: http://www.wireworldcable.com/categories/usb_cables.html
Or what about an optical USB cable? It will provide 100% galvanic isolation from the PC!
A long optical cable is tempting, also because I can hide away the bulky and noisy PC in another room. They can be sourced from several places.
Here is one example: http://industrialcomponent.com/opticis/opm210003.html
-But it is only restricted to USB 1.1 capacity.  Sad
To put this in perspective:
2 channels of Red Book CD: 2*16* 44100 = 1.4Mbps.
2 channels of 24/96         : 2*24* 96000 = 4.6Mbps.
2 channels of NOS1 USB   : 2*24*768000 = 37Mbps.
USB 1.1:  12Mbps max capacity.
USB 2.0: 480Mbps max capacity.
USB 3.0: 4-5Gbps max capacity.
-PETER: Do the NOS1 USB connection require any specific technical minium standard?
« Reply #1 on: September 21, 2011, 02:51:10 pm »
When searching the WWW for a suitable solution, the keywords are "USB 2.0", "fibre", "extender", "galvanic isolation" etc.
For example, I found this clever product costing only €34.-, BUT after reading the fine print it is restricted to only 12Mbps...  unhappy
http://electronicsshop.dk/?id=1038
« Reply #2 on: September 21, 2011, 03:15:46 pm »
Whatever it is you think you need, you will need a 480Mbs version ...
« Reply #3 on: September 21, 2011, 03:38:07 pm »
Yes. And the only one I found so far is this "professional" solution providing true 480Mbps at 500mtr: The USB Ranger 2224 Multimode Fiber Extender. The only downside is the cost of $900.-...
Product link: http://www.smartvm.com/usb-ranger-2224-multimode-fiber-extender-p43447.htm
Also, I found a related thread on the ComputerAudiophile forum in this matter.
« Reply #4 on: September 21, 2011, 04:09:55 pm »
Hi Pedal,
http://www.shop.bt.com/content/uni2/documentation/4ppw/belkin_network_hub.pdf
I have used this one before with another DAC and it seems to be USB2.0. I never found it slow and worked well...
Not sure if it is compatible with the NOS1 USB DAC though as I can't test that myself.
At least it is a lot cheaper than the one you've found... ;-)
Problem will be the network activity though...
« Reply #5 on: September 21, 2011, 05:02:38 pm »
Will never work Bert.
Pedal, isn't it strange behaviour to start with selecting USB cables or anything, while you didn't even open the box yet ?
The $900 one you mentioned is about the only thing there is - or is the cheapest. It may work, it may not. Next, I'm pretty sure that these things will work out for the worse. That means : not for the better.
The only option is a "normal" USB cable, and you don't hear me say that it will - or can be better. May it help, I use the one which is in the box. Ok ok, I know of someone where *that* did not work at all, but that was because it was broken.
If you or anyone perceives a difference outsided placebos, I'm glad to hear about it. yes
« Reply #6 on: September 21, 2011, 05:54:11 pm »
No, because it is not USB 2.0 High Speed.
Yes of course, he-he!  blush1
-Actually this was only me doing a little advance planing. I had a USB DAC 3 years ago. At that time I kept my music-PC in the basement, with a 10m USB 1.1 optical cable running through the floor and up into my living room on 1st. floor. The USB cable is still there ready to be used. However after checking the numbers I realized today that it's capacity of 12Mbts is too low for the NOS 24/768. So I was looking for a USB 2.0 optical cable replacement.
But it can wait. Now, I will be a nice boy and let the PC remain where it is and use the enclosed short standard USB cable. In this way there will be no changes to the system, enabling me to focus solely on the SQ of the NOS1 update.  sounds good !
I guess NOS1 USB does not use the 5V option? If so, there is also less reason to shop for "dedicated" USB cables, because the cable will not carry any voltage.
« Reply #7 on: September 21, 2011, 07:01:02 pm »
Correct (internal linear PSU). But careful with the scizzors, because it *is* connected and wihout that things will cease working.
« Reply #8 on: November 20, 2011, 05:43:42 pm »
I wonder if connecting the usb mouse and keyboard to the PC affects the sound. I´m talking about the new NOS1 USB.
I´d like to know how the owners of a NOS1 USB have the mouse and keyboard connected to the PC to avoid influences at the usb NOS1 connection.
praphan
« Reply #9 on: November 22, 2011, 04:22:18 pm »
Hello Juan,
I use dedicated USB board to drive NOS1 USB. Please read this thread. It works for me.
http://www.phasure.com/index.php?topic=1826.0
Good luck!
Praphan
« Reply #10 on: November 22, 2011, 06:20:43 pm »
Hello Juan,
Good luck!
Praphan
Thank you Praphan, I read it when you posted it. Now I think that I´ll wait for a while to make changes, meanwhile I´ll continue reading the posts on this issue.
I use some kind of power cleaner made by a technician/friend here with transformers and RF filters and I connect to it the NOS1 and the computer, (it has two isolate parts), I connect also the computer with a Foundation Research cable that has a kind of RF also. For the NOS 1 I use a Grover Huffman pc with no further filters.
« Reply #11 on: October 26, 2013, 10:19:02 pm »
Thanks to to generosity of Alain I´m using now a Mapleshade Clearlink Plus USB 2.0 cable to connect the PC, via the PCIe USB 3.0 card, to the NOS1. I can confirm some other´s opinion about this cable: The sound is clearer and smoother compared to the standard USB2.0/3.0 cables. Let me repeat it, the sound is CLEAN , it seems like that there is no other noise than the music. It doesn´t hide any change made in the software or hardware, on the contrary those changes are even more evident. It is a pleasure to listen music with this cable, thanks Alain!
http://shop.mapleshadestore.com/prodinfo.asp?number=USBLINK3P
« Reply #12 on: October 27, 2013, 06:26:14 am »
Or thank Jud (if it is about advising this cable).
« Reply #13 on: October 27, 2013, 10:55:37 am »
I do not want to forget Jud as he has the merit of being the first one to bring that cable to the forum. Therefore, thanks Jud.
But I spoke of generosity and so I mentioned to Alain. He had two identical cables and gave me one, yes, a gift, zero money, nothing. In exchange for what then? We developed a friendship based on emails in which we talk about our systems, about the snow in Canada or the sun in Spain and of course about some other personal things. A great guy this Alain and always exquisitely friendly.
Taking advantage that today is Sunday and I feel happy I would like to thank someone else, but not just for the cable in this case but for a sense of permanent companionship. Thanks to the XXHighEnd forum in general because it is the place where we all fit in equal, those who know much with those who know less, those with sophisticated systems and those with a more simple system. A place also where friendships can be born. So thank you all.
You see Peter, now I have not forgotten anyone haha . Happy Sunday!
Jud
« Reply #14 on: October 27, 2013, 11:46:38 pm »
I can confirm what a pleasure it is to correspond with Alain (and Peter).  And it is good to hear the cable is working well for you, Juan.
